Door lock problems
Old Oct 7, 2008 | 09:08 AM
CompanyFlow's Avatar
Default Door lock problems
Ok so my drivers side door lock is acting stupid. I cant turn the key in either direction initially, but if I jimmy it a little, I can get it to LOCK the door. Getting it to unlock the door take a little bit of work and about 5 minutes. What can I do to get this damn thing to work (or just open when I turn the key)
Old Oct 7, 2008 | 09:34 AM
AWD Terror's Avatar
Default Re: Door lock problems (CompanyFlow)
Did you try spraying anything into the lock?
Old Oct 7, 2008 | 09:42 AM
SuzukaBlueAP2's Avatar
Default Re: Door lock problems (AWD Terror)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by AWD Terror &raquo;</TD></TR><TR><TD CLASS="quote">Did you try spraying anything into the lock?</TD></TR></TABLE>
x2 liquid graphite or wd-40 if you have nothing else
Old Oct 7, 2008 | 09:48 AM
AWD Terror's Avatar
Default Re: Door lock problems (SuzukaBlueAP2)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by SuzukaBlueAP2 &raquo;</TD></TR><TR><TD CLASS="quote">
x2 liquid graphite or wd-40 if you have nothing else</TD></TR></TABLE>
And have a rag on hand to make sure you don't get too much on your paint.
Old Oct 7, 2008 | 12:06 PM
90_EX_Civic's Avatar
do you know if someone had tried to break into your car? what year teg is it again?
Old Oct 7, 2008 | 12:19 PM
ac_attak's Avatar
I have keyless entry so keys have never really been used in my door locks and i have the same problem. I have bent a few keys trying to get it to turn, but nothing. Sprayed lots of rust check in there, nothing. If i ever lost my only remote i'd have to use the trunk to get into the car LOL.
Old Oct 8, 2008 | 05:18 AM
Default Re: Door lock problems (90_EX_Civic)
Its a 97 GSR body. I dont think anyone tried to tamper with the lock because there is no (visible) damage. It isn't they key because it works on the other side. I can get it to lock if I Ace Ventura shake the key but not unlocking.I will try spraying wd-40 but I don't think that's gonna work.
Old Oct 8, 2008 | 05:33 AM
if spraying a lube in there doesn't help maybe you should take the door panel off and check for obstructions under the door panel?
it's probably a long shot, but, just a thought.
Old Oct 8, 2008 | 08:39 AM
Well I'm thinking of swapping the passengers side mechanism with this one. I never use that side anyways.
Old Oct 8, 2008 | 10:05 AM
I fixed the son of a bitch. I went outside to clean up dog poop and just stared at my door the whole time, prompting me to spray the **** out of it with WD (which didn't work) and eventually I took off the door panel (which I absolutely hate to do). I checked the two lines and they were both unobstructed and fully operational. I looked at the actual lock while toggling the auto lock button back and forth and couldn't figure out why it wouldn't open with a key. I used the button to open it with the key in the hole and it fixed itself. It seemed as though I didn't have enough leverage before to turn it to open, or as if I was lifting something heavy with the mechanism but it seemed to have come loose when I unlocked it from the inside with the key turning to the open position. I sprayed everything down real good with wd40 and ghetto rigged a straw to my can so I could get inside the lock itself. Again, I have no idea how it got fixed but it did.
Old Oct 8, 2008 | 10:11 AM
ekred9's Avatar
hahaha good stuff!
i was gonna say get an actuator installed
Old Oct 10, 2008 | 12:00 AM
Default Re: Door lock problems (ekred9)
Meh. Theres no space to work inside the door so that would have been a PAIN. I'm just glad it freed itself up. Now I unlock the door and its so smooth that it makes me smile every time. Simple pleasures
EHbOOSt07
Honda Civic (2001 - 2005)
Oct 7, 2008 10:43 AM
Zackbreakiron
Honda Civic (2006 - 2015)
Aug 6, 2008 07:36 AM
drunknmonkey18
Apr 7, 2005 05:38 AM
JimmyAtlantis
Jan 13, 2004 07:25 AM
CroSi
25
Dec 8, 2003 11:05 PM
