Hatch issue?
Old Oct 13, 2008 | 12:48 PM
The_Ricky_Is's Avatar
Default Hatch issue?
Alright, i tried searching to see if any one else has had this problem, but no luck.
i drive a 00 gsr and my hatch doesn't open any more.
i tried to unlock it from the inside and tried it with the key.
i hear the motor trying to unlock it, but it just doesnt open.
has any one ever ran into this problem or knows how to fix it?
any help would be greatly appreciated.
Old Oct 13, 2008 | 10:26 PM
BAYsikDC4's Avatar
Default Re: Hatch issue? (The_Ricky_Is)
my car is the same way im thinking its the motor or probaly the latch itself, but if you turn the key until the hatch pops hold the key there all the way to the right and unlock the hatch with lever at the same time while you hold the key and the hatch should open.
Old Oct 13, 2008 | 11:01 PM
choji's Avatar
this happened to me just a few months ago, it turned out to be the hatch actuator. if you pull the lever and you hear the motor moving and nothing's happening then it's the actuator. here's the article i used.
http://www.team-integra.net/se...=1117
Old Oct 14, 2008 | 04:41 AM
weavertime1's Avatar
Default Re: (choji)
This is a very common issue on '98 - '01 integra 3 doors, and yes most of the time it turns out to be the actuator. It is located behind the rear interior plastic panel (the one you have to remove to get at the tail lights). Good luck!
Old Oct 14, 2008 | 11:19 AM
Default Re: Hatch issue? (BAYsikDC4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by BAYsikDC4 &raquo;</TD></TR><TR><TD CLASS="quote">my car is the same way im thinking its the motor or probaly the latch itself, but if you turn the key until the hatch pops hold the key there all the way to the right and unlock the hatch with lever at the same time while you hold the key and the hatch should open. </TD></TR></TABLE>
i actually tried that before i posted the thread. hahah<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by choji &raquo;</TD></TR><TR><TD CLASS="quote">this happened to me just a few months ago, it turned out to be the hatch actuator. if you pull the lever and you hear the motor moving and nothing's happening then it's the actuator. here's the article i used.
http://www.team-integra.net/se...=1117</TD></TR></TABLE>
do you know how much the actuator would cost and is it hard to install myself?
Thanks again for the help guys
Old Oct 14, 2008 | 11:29 AM
If you click on the post choji you will see that everything is in there. I believe that it was $60.00. Good find anyway by choji , as this is a common problem on 98 - 01 integras. Good luck!
Old Oct 14, 2008 | 02:13 PM
TunerN00b's Avatar
If you keep turning the key further than necessary to unlock the power locks, it will pop the trunk without that actuator working. Mine hasn't worked in over 2 years, I just use the key to open the trunk.
Old Oct 14, 2008 | 05:41 PM
Default Re: Hatch issue? (TunerN00b)
thanks for all the help guys, i ended up fixing it today!
thundernoodle
Apr 28, 2010 06:35 PM
zach1288
Jul 20, 2009 12:28 PM
works909
Oct 18, 2006 03:12 PM
xJ.SLOTHx
Jan 13, 2004 07:11 PM
Alexander
May 24, 2002 01:03 PM
