ngk spark plugs differences?
Old Feb 21, 2002 | 01:43 PM
liam821's Avatar
25 Year Member
Default ngk spark plugs differences?
People recommend NGK BKR7E-11 and NGK BCPR7ES-11 for turbo use. But what is the difference between them? Is one better then the other? I did some searchs here and nobody seem to have that answer. I found one post on clubSI which said the tips are the same but the heads different. They have the same heat range and the same gap, but should i be running one and not the other?
I needed some spark plugs and bought the bkr7e-11 but maybe i should have gotten the bcpr7es-11?
My setup is d16 + vtec + turbo (7-9psi).
thanks,
liam
Old Feb 21, 2002 | 01:58 PM
98hx99b18c's Avatar
Default Re: ngk spark plugs differences? (liam821)
Try a search, the spark plug issue has been covered many times.
Old Feb 21, 2002 | 02:03 PM
liam821's Avatar
25 Year Member
Default Re: ngk spark plugs differences? (98hx99b18c)
i did do a search and read every post...but they were all "i run the bkr" and somebody else says "i run the bcs". But nobody described the differences between the two.
liam
Old Feb 21, 2002 | 02:09 PM
98hx99b18c's Avatar
Did you try the archived topics? All the good info is there. HTH
Old Feb 21, 2002 | 02:14 PM
Ben Huynh's Avatar
The main difference:
The BKR plugs have a projected tip.
Old Feb 21, 2002 | 02:22 PM
liam821's Avatar
25 Year Member
Default Re: ngk spark plugs differences? (ben@importparts.com)
thanks ben, thats the information i was looking for.
liam
B18B1DOHC
Nov 17, 2003 02:08 PM
jeremy.
Aug 21, 2003 05:39 PM
nsx-Animal
Jul 30, 2002 04:22 AM
redteg1
Jul 23, 2002 11:09 PM
