lenso rims
Old Feb 21, 2002 | 11:09 AM
PROFILES2000's Avatar
Default lenso rims
i did a search and couldnt find anything usefull on these rims im looking for the 13 inch drag rims what are the sizing of them do you need wheel spacers and longer studs? also where can i get them and how much do they go for?
also pic would be help full too
thanks
Old Feb 21, 2002 | 11:12 AM
b18bturbo's Avatar
Default Re: lenso rims (TurboGsR.com)
axiswheels.com they distribute them,
http://axiswheels.com/lenso
[Modified by b18bturbo, 2:12 PM 2/21/2002]
Old Feb 21, 2002 | 11:26 AM
Default Re: lenso rims (b18bturbo)
oh yah the other question i had was will they fit over my breaks with out modification
Old Feb 21, 2002 | 11:38 AM
b18bturbo's Avatar
it fits factory brakes fine. I am not sure about the aftermarket setups.
Old Feb 21, 2002 | 11:46 AM
newsense's Avatar
New User
With Lenzos you do not need longer studs. You can use the stock lug nuts. I considered getting them and getting rid of my bogarts. I dont have the longer studs and im getting tired of using the spacer and longer lug nuts.
Old Feb 21, 2002 | 12:01 PM
1fstevo's Avatar
New User
Default Re: lenso rims (newsense)
But isn't NIRA rule for drag slicks to have long studs anyway? It's safety rule.
Old Feb 21, 2002 | 12:21 PM
Default Re: lenso rims ([Evo]Hybrid)
ive never heard that before are you sure?
Old Feb 21, 2002 | 12:49 PM
b18bturbo's Avatar
nira rull books is no longer valid. They got bought off by NHRA. So look at the http://www.NHRAIMPORT.com website and read about the new rules.
Old Feb 21, 2002 | 12:54 PM
b18bturbo's Avatar
5:2 WHEELS
Hubcaps must be removed for inspectors, who will check for loose
lugs, cracked wheels, worn or oversize lug holes, and condition of
spindles, axle nuts, cotter pins, etc. Snap-on hubcaps are
prohibited on any class car. Each car in competition must be equipped with
automotive-type wheels with a minimum 12 inches
of diameter unless class requirements stipulate otherwise.
All wheel studsmust project into the hex portion of the lug nut by a distance equal to Diameter of stud At least diameter of stud Lug nut Washerone diameter of the stud. Maximum rim width on any car: 16
inches. No rear-wheel discs or covers permitted in any category.
Old Feb 21, 2002 | 01:04 PM
ArizonaTurbo's Avatar
I have a set of used 13x7.5 Lenso drag wheels w/ M&H 22x8x13 slicks and a set of 15x6.5 Lenso wheels w/ Toyo 195/50/15 tires. I am asking $800.00 for all 4 wheels and tires!
Old Feb 21, 2002 | 05:04 PM
1fstevo's Avatar
New User
Forgot, I need long stud for my wide slicks.
Old Feb 21, 2002 | 07:41 PM
ok ill take that into consideration
but if i am correct that would just be for nhra events right? and not other events held at the track
mr__orange97
Mar 1, 2008 10:37 AM
SaYjAiBaO
Mar 26, 2007 10:15 PM
backyarddc5
19
Oct 10, 2004 05:45 AM
Fuster_Cluck
Nov 28, 2003 11:46 AM
D21X
Apr 17, 2002 04:50 PM
