DSM injectors?
Old Feb 25, 2002 | 11:15 AM
InfamousRS's Avatar
Default DSM injectors?
I did a search, I skimmed over tons of archive topics on them.
What generation do the 450's come off of?
What all is needed to run them with Hondata?
A few posts said you need a CUSTOM resistor box, and some say you just need a stock Honda resistor box from a early Civic? Which one, where do you get a custom box at?
I also read one post that said you need the RC adapeter clips to run the DSM injectors on Hondas?
About how much would a set of 4 cost?
I read tons of stuff on them, but didn't get many straight answers!!!
Old Feb 25, 2002 | 11:34 AM
b18bturbo's Avatar
Default Re: DSM injectors? (BLK94RS)
go to DSM website look for injectors usually the price ranges from 100-150 max for complete set. Not really that expensive.
Second thing you can run the hondata with payntech resistor box its the easy way of doing things or use the resitor from a honda either way it works.
Finally the 450cc come from GEN! turbo 5spd.
Old Feb 25, 2002 | 11:41 AM
InfamousRS's Avatar
Default Re: DSM injectors? (b18bturbo)
What is the DSM web address? I looked at http://www.dsmtreader.com but really couldn't find many 450's for sale.
Where do you get the Payntech resistor box at? How much does it cost? Is it better than running the Honda resistor box?
What does that mean? They come frome an Generation 5 speed turbo?
Thanks for the info.
Old Feb 25, 2002 | 11:43 AM
b18bturbo's Avatar
they come from a generation I 5spd which is the older dsm cars.
dsmtrader.com is one place. Thepartstrader.com is the other place. And local scrap yards are another good stop for these inejctors.
The payntech resistor box is like 70 bucks. I know the hondas ones from scrapyards are 20-30 usually.
Old Feb 25, 2002 | 11:47 AM
dbman96's Avatar
New User
Or you can buy four 10-ohm 10-watt resistors from Radio Shack for like $4.50 and splice them into the injector leads. If you don't understand how resistors work or how to wire a resistor in series with something, don't ask, just go buy a resistor box and be back in a week asking how to wire it up.
Old Feb 25, 2002 | 11:48 AM
InfamousRS's Avatar
Is it better to run the Payntech box or Honda box? Where could I find the Payntech box at?
Old Feb 25, 2002 | 11:49 AM
dbman96's Avatar
New User
http://cgi.ebay.com/ebaymotors/aw-cg...684690&r=0&t=0
Do a search on Ebay the damn things are all over the place.
Old Feb 25, 2002 | 01:07 PM
RAWB's Avatar
Is there a difference between the Gen1 and Gen2's?
Old Feb 25, 2002 | 01:17 PM
lswithvtec's Avatar
New User
Default Re: DSM injectors? (integracon)
i hear that all 450cc comes in either the first or the 2nd gen turbo car.. and the auto ones are like 350 or 360 i think.. so you have to make sure it is off a 5 speed turbo one.
Old Feb 25, 2002 | 01:23 PM
RAWB's Avatar
Default Re: DSM injectors? (lswithvtec)
Well I was told the 5spd turbo injectors are 450cc, reagrdless of which generation their off of. I just got ahold of some off a 99GSX ones, and was under the understanding they would fit. Another member on the board said he was runnin the same injectors on his 92 civic(with the use of a resistor pack) I just wanted to make sure I wasn't going to get an unexpected surprise when I went to install them on my car.
Old Feb 25, 2002 | 01:38 PM
InfamousRS's Avatar
I checked http://www.thepartstrader.com out, there are several sets of 4 1st gen for under $60.
Does anyone know if there is an advantage to running the Payntech resistor box over the Honda resistor box?
Can anyone confirm that the 450's come off of any 5spd turbo? If so, what generation would be most compatable with my 94 b18b and obd1 ECU?
Old Feb 25, 2002 | 02:00 PM
RAWB's Avatar
DEFINITELY 450cc on DSM Turbo Eclipse/Talon cars. I know ALL are Peak/Hold type which require OBD cars to use the resistor pack. Still waiting for a confirmation of 1st gen vs. 2md gen's.
Old Feb 25, 2002 | 02:08 PM
InfamousRS's Avatar
Thats mostly what I wanted to know too. Im pretty sure there is a 90ish Turbo eclipse, not sure if its 5spd or not, at one of the wrecking yards in my area. I may go see I can get them for cheep even though I won't even need them for a LONG time!
Old Feb 25, 2002 | 02:10 PM
LsTurbo91's Avatar
I've got some 450's (peak/hold) came off my 91 LS, zdyne 450's, 100shipped if you want it.
Old Feb 25, 2002 | 03:22 PM
Hayasa15's Avatar
Default Re: DSM injectors? (LsTurbo91)
390 dsm auto
450 dsm manual
450 are from the newer gen i am for sure. Might also be in the older but not for sure.
Old Feb 25, 2002 | 05:25 PM
InfamousRS's Avatar
Default Re: DSM injectors? (Hayasa15)
What are the different years of the 1st, 2nd, and 3rd gen eclipses?
Old Feb 25, 2002 | 07:29 PM
ElectronVTEC's Avatar
My 450's came off a '95 5 speed GSX. They are for sure 2G and I see no reason why the 1G's would have used less. Peace, EV.
Old Feb 25, 2002 | 09:57 PM
lbz34's Avatar
Default Re: DSM injectors? (ElectronVTEC)
my dsm injectors say "B450L" on the side of the clip housing. this looks like stock stamp, although i do not know what year they came out of. the local dsm guys sold them to me for 25.00/set. i got the resistor box off of an early 90's accord. like 25.00 from the junkyard. have yet to run them (i did have them cleaned, flowed, balanced) i am just waiting for my hondata to come back. then turbo time.
Old Feb 25, 2002 | 11:31 PM
InfamousRS's Avatar
Default Re: DSM injectors? (lbz34)
i did have them cleaned, flowed, balanced.
Did RC do that, how much did it cost? Is it a good idea before running a 10 year old injector?
Old Feb 26, 2002 | 12:03 AM
speed_daemon1's Avatar
New User
here's where I got the info: http://www.hostboard.com/ubb/Forum40/HTML/009323.html
Old Feb 27, 2002 | 03:44 PM
16g-95gsx's Avatar
Default Re: DSM injectors? (speed_daemon1)
The 1g Automatic DSM's did in fact have less CC's, trust me on this one for anyone doubting it. The 2g's had the same amount of fuel for each car but the 1g's didnt. The 1g's auto turbo was slightly smaller, it was the 13g as opposed to the 5spd's 14b. There's my dsm facts of the day. Later
ceemarun
Aug 7, 2015 05:21 PM
b16ajdmrex
Apr 5, 2009 07:33 PM
mortificationrock
Jun 10, 2007 09:05 PM
b17a1crx
Sep 10, 2006 07:27 PM
sivik2nr
Jun 11, 2003 09:59 PM
