What's the biggest bore the OEM head gasket can accept?
With a 83MM bore ... get OEM gasket or cosmetic?
I will also get the block 0-ringed (Golden Eagle)
Re: What's the biggest bore the OEM head gasket can accept? (BlackGSR)
On the 84mm bores you need to take it to a competant machine shop to have the oem gasket modified. im pretty certain that at 83mm you would need to do the same thing.
Re: What's the biggest bore the OEM head gasket can accept? (b18bturbo)
Just order your custom size and thickness from Cometic. I've reused my my current gasket twice
Eghatchgsr8
09-19-2014 02:24 PM
97CTR
14
07-18-2004 01:47 PM
