Who makes a 83+mm piston (turbo app)
Since I want the Golden Eagle treatment, I figure it would be nice to bore the block a little. I would like to stay safe with a 83 bore.
What companies make a 83 piston?
I have a B18C block with a ITR head. I want a 10:1 compression piston, which will be 9.7:1 when installed.
I like having higher CR and less boost.
Re: Who makes a 83+mm piston (b18bturbo)
What compression is the JE piston? I really don't want LOW compression. I want to run higher compression and lower boost.
Remember, the ITR head will lower the compression by .2-.3 pts.
its custom piston from them you can get what ever compression you want. 10.1 wont be too bad for you.
Do you know where I can order these puppies?
Re: Who makes a 83+mm piston (BlackGSR)
I had one set in stock but jsut sold it to fellow freind. You can then through raceeng.com or through importparts.com. I am pretty sure ben can work you a deal. I could get them for you also but it might take longer since i dont ahve them in stock. maybe one of them might.
thats is correct.
Thanks for all your help!
YOSOLO CRX
13
11-13-2003 08:53 PM
