does 300whp make 3rd gear spin
Old Feb 25, 2002 | 11:33 AM
b18cTurbo's Avatar
Default does 300whp make 3rd gear spin
im just curius ,does 300 whp whit 205 50 15 on yokohama a520 will make lots of spin in 3rd gear??
Old Feb 25, 2002 | 11:37 AM
b18bturbo's Avatar
Default Re: does 300whp make 3rd gear spin (mikvtec)
it can make it spin but thats shouldnt be your concern. Getting that pwr to the ground should be your concern.... more pwr to the ground = faster times.
Old Feb 25, 2002 | 11:49 AM
boosted hybrid's Avatar
Yeah it does. I can spin into 5th alittle with my street tires. Tire spin sucks ***...i wish i just had grip...ahhh...wouldnt that be something.
Old Feb 25, 2002 | 11:58 AM
b18cTurbo's Avatar
Default Re: does 300whp make 3rd gear spin (boosted hybrid)
spin on 5th gear are you running on 13 inch rim?so you must be saying that your 4th spin like hell to
Old Feb 25, 2002 | 11:59 AM
DIRep972's Avatar
Smarter than you
what about off a 40 punch? when I floor it off 40 in 2nd I always chirp third.. I wonder if it would spin bad with 300
Old Feb 25, 2002 | 01:00 PM
BoostinDC2's Avatar
Default Re: does 300whp make 3rd gear spin (DIRep972)
im making 315whp and i dont get spin in 3rd but 2nd is a different story
Old Feb 25, 2002 | 01:16 PM
b18cTurbo's Avatar
Default Re: does 300whp make 3rd gear spin (BoostinDC2)
what your wheel and tire dimension?
Old Feb 25, 2002 | 01:37 PM
chri5's Avatar
I used to be able to spin 3rd with the JRSC. Stock tires are ghey that way.
Old Feb 25, 2002 | 01:45 PM
D-Man's Avatar
Default Re: does 300whp make 3rd gear spin (Strng1dah)
depends on your final drive too.like with 4.90s,should do it easy
Old Feb 25, 2002 | 01:48 PM
immortal's Avatar
Banned
Default Re: does 300whp make 3rd gear spin (D-Man)
220 horsepower in my friends turbo gsr hatch makes 3rd gear spin a little bit........
we finally get traction low-mid third.
Old Feb 25, 2002 | 01:56 PM
Yeah i am running around with the jdm itr tranny, 14'' wheels with winter tires...there is just no traction at all. Even when i was n/a i would still spin into 4th slighty...basically just a chirp.
Old Feb 25, 2002 | 01:59 PM
TurboIntegra's Avatar
Quaife LSD + drag radials = drastically reduced wheel spin.
LSD is something every turbo FWD should have.
Old Feb 25, 2002 | 02:09 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: does 300whp make 3rd gear spin (TurboIntegra)
Hopefully mine will be running in a few days.
Old Feb 25, 2002 | 02:31 PM
Tomakit's Avatar
JDM ITR tranny and boost...hahahahahaha (not making fun...just laughing at how bad tractions must be for you)!!!!!
Tom
Old Feb 25, 2002 | 02:50 PM
b18cTurbo's Avatar
Default Re: does 300whp make 3rd gear spin (Tomakit)
whats the diff between quaife and itr lsd??
Old Feb 25, 2002 | 02:58 PM
2000_Civic_Si's Avatar
I spin 3rd with my car making 170hp. Thanks, Clutchnet Stage 2.
Old Feb 25, 2002 | 03:40 PM
Yeah traction sucks a fat one. But when i do run slicks and i stick...look out! I have never been in a faster accelerating car. I have to stop borrowing my friends slicks...one of these days i will buy a pair.
Old Feb 25, 2002 | 03:46 PM
89civic1.8T's Avatar
I am not making alot of power with my B18B turbo (<200 whp) setup but one time at the track on a cold night I was spinning 3rd gear pretty hard. I was breaking loose from my hard shifting and letting the clutch fly home. My times where 14.0 @ 105 with a 2.389 60 ft.
Old Feb 25, 2002 | 03:48 PM
DLB1994's Avatar
Default Re: does 300whp make 3rd gear spin (2000_Civic_Si)
it all matters what tranny u got and your gearing
any itr or b16 tranny is going to spin a lot more then a b18a or b18b tranny at 300hp
most itr trannys don't even get full boost in first gear the gear is crazy short in a itr and a jdm s1 tranny
Old Feb 25, 2002 | 03:49 PM
GSRwBOOST's Avatar
250-300whp here.. w/ quaife lsd and khumo 712's and first and second spin totally with third hooking up after a nice chirp... then rocketing off into space!!
Old Feb 25, 2002 | 04:02 PM
b18cTurbo's Avatar
Default Re: does 300whp make 3rd gear spin (GSRwBOOST)
lol space
Old Feb 25, 2002 | 06:26 PM
Anthony K's Avatar
New User
If you wanna spin all the way through 3rd, get some Dunlop D60/A2 tires. You will not grip in third gear when they're really cold.
Old Feb 25, 2002 | 06:32 PM
DIRep972's Avatar
Smarter than you
Default Re: does 300whp make 3rd gear spin (89civic1.8T)
how did u run at 105mph with only 200whp? u sure about that? 200whp will get u more like 100mph traps.. 230-240 will net around 105.. maybe u r making more hp then u think
Old Feb 25, 2002 | 06:41 PM
Phantom's Avatar
you also have to consider weight of the vehicle
Old Feb 25, 2002 | 06:46 PM
Darin D.'s Avatar
i ran between 106-109 mph when i had 196@wheels with my all motor setup. I could also spin all through 3rd and a little of 4th if I tried and a nice hard chirp into 5th. It all depends on your suspension and tires.
