Lets try this again.
Old Feb 26, 2002 | 06:45 PM
DRAGLS's Avatar
Default Lets try this again.
[Modified by DRAGLS, 1:00 AM 3/6/2002]
Old Feb 26, 2002 | 06:47 PM
D-SPEED's Avatar
Default Re: Lets try this again. (DRAGLS)
psi ?
Old Feb 26, 2002 | 06:51 PM
DRAGLS's Avatar
Default Re: Lets try this again. (D-SPEED)
14 psi on a stock motor, running way to rich
Old Feb 26, 2002 | 06:56 PM
D-SPEED's Avatar
ringlands no likey
Old Feb 26, 2002 | 07:10 PM
LsTurbo91's Avatar
thats nice!! what fuel management are you running!?
Old Feb 26, 2002 | 07:11 PM
paulzy's Avatar
Default Re: Lets try this again. (LsTurbo91)
nice
Old Feb 26, 2002 | 07:14 PM
Ri5e's Avatar
Default Re: Lets try this again. (Slow_ass_4dr)
nice, nice. How did you pull such high numbers? Tell me your secrets.
Old Feb 26, 2002 | 08:07 PM
SYDNEYSIDER's Avatar
ok youve got Teg LS right. and running 14psi on the stock motor. what's your setup??
Old Feb 26, 2002 | 09:31 PM
shamoo's Avatar
Will you make something up for me please?
Old Feb 26, 2002 | 10:07 PM
SIK IN DA HED's Avatar
New User
Default Re: Lets try this again. (shamoo)
yah, whuts your setup?
Old Feb 26, 2002 | 11:16 PM
turbopimp's Avatar
set up please....
Old Feb 27, 2002 | 02:10 PM
DRAGLS's Avatar
Default Re: Lets try this again. (turbopimp)
setup= Drag III , S-afc, S-itc, RC 440s,cartech regulator, skunk 2 manifold, 64mm RC throttle body, and 14psi and from what u guys can see my air/fuel is off the chart way to rich I can say lean it out to 12.7 to 11.1 I can easily pull off 360 to 375hp. Don't believe it come to Orlando and we will go to dyno together.
Old Feb 27, 2002 | 02:13 PM
2000_Civic_Si's Avatar
Good numbers!
Old Feb 27, 2002 | 02:16 PM
BoostinDC2's Avatar
Default Re: Lets try this again. (2000_Civic_Si)
Nice Numbers!!!!
TurboMiata's Avatar
Good lord.....Your factory ignition actually ignites that mixture?!
What plug gap? .20? .10?
BTw, I think maybe its time for a standalone there..
Old Feb 27, 2002 | 02:18 PM
TurboMiata's Avatar
Oh yeah..... No built bottom end? Do you seriously expect this to last very long? High rpms + boost on rods made for only high rpm wont last very long.
DRAGLS's Avatar
Default Re: Lets try this again. (TurboMiata)
.o21" to .o25" plug gap, not a miss ever.
Old Feb 27, 2002 | 02:21 PM
DRAGLS's Avatar
Well I am past the 3 year mark, so what do u think? Also my LS only revs to 6800.
Old Feb 27, 2002 | 02:25 PM
TurboMiata's Avatar
6800? I thought it was higher for some reason.....
3 year mark eh? Dont "get on it" much do you.
Oh yeah, upgrade the ignition and run stock spark gap. You'll see a more complete burn. You will have less knock, and can run more ignition advance for more HP. fwiw......
[Modified by TurboMiata, 6:26 PM 2/27/2002]
Old Feb 27, 2002 | 02:28 PM
DRAGLS's Avatar
To tell you the truth I baby her LIke u wouldn't believe. 1500 mile oil changes, she sees maybe 40 miles a week. nice having two cars.
Old Feb 27, 2002 | 02:39 PM
LsTurbo91's Avatar
is the head stock?
Old Feb 27, 2002 | 02:40 PM
_Shadow_'s Avatar
New User
all that power and you hardly ever drive it....what fun is that?? BTW nice #'s
Old Feb 27, 2002 | 02:41 PM
TurboMiata's Avatar
thought so
Anyhow.....I would look into an electromotive TecII or III if I were you. Best ECU you can get short of a motec IMO. (III has more features, but spark and fuel are handled the same pretty much afaik)
When running as much HP as you are through a stock block, its best NOT to screw around with finicky, very coursely tuning "black boxes".
Crank triggered ignition w/ 60-1 motronic wheel + wideband O2 sensor + low egt = good margin of safety.
BTW, you guys know that O2 sensors are finicky devices as well, right? Heat affects them, and location affects them. Too high of EGT's means the O2 sensor is being affected as well. Too low of EGTs and the O2 sensor is being affected.
FWIW, .02, blah blah blah.....
Old Feb 27, 2002 | 04:30 PM
DRAGLS's Avatar
head is stock.
Old Feb 27, 2002 | 04:31 PM
DRAGLS's Avatar
sorry haltech is the way to go
