Chrome compressor housing...
Old Feb 26, 2002 | 06:52 AM
blowncivichb's Avatar
Default Chrome compressor housing...
Anyone think that getting the compressor housing chrome dipped will cause any heat retention problems?
I like to polish it, but polished finishes are high maintenance.
Any feedback is appreciated. Thanks.
Old Feb 26, 2002 | 07:01 AM
Mr. Vapor's Avatar
Default Re: Chrome compressor housing... (blowncivichb)
awesome questoin! id also like to know
Old Feb 26, 2002 | 07:32 AM
b18bturbo's Avatar
it really doesnt matter if it does retain heat becuz as it is it is going to flow what air it has through and intercooler and then through your TB. So really polisihing and chroming is just for looks.
Old Feb 26, 2002 | 07:40 AM
ArizonaTurbo's Avatar
The Chrome plating will retain more heat than just the polished aluminum, but I am not too sure if the difference will be that significant! Do you have a pyrometer? I would be interested in checking out what the differences are on identical setups , one using a polished compressor housing and the other one chrome plated.
Old Feb 26, 2002 | 07:51 AM
b18bturbo's Avatar
Default Re: Chrome compressor housing... (APEXSER)
i can check with the heat gauge i got that i use for the track. Thermal heat gauge i got chrome-dipped housing and i have a std one.
I really dont think it really would make a difference in performance. But iwll make a difference in underhood heat.
Old Feb 26, 2002 | 09:48 AM
Default Re: Chrome compressor housing... (b18bturbo)
If it'll make a diffference in underhood temps like you say, then it'll for sure make a performance difference. If the chrome increases the temp inside the compressor housing, that temp difference will probably be measurable at the throttle body.
Old Feb 26, 2002 | 06:46 PM
Anyone else have any input???
No one on this board has done this?
Old Feb 26, 2002 | 07:15 PM
AlphaKennyWun's Avatar
Bare aluminum cant be chromed. The process to chrome aluminum is this: first a layer of a metal, namely copper, is attached to surface of the aluminum and then it is chrome plated.
A chrome plate is not the best surface to expand and contract like a turbo does through heating and cooling. The plating will flake off with time. Before that, however, it will probably turn a blue hue. Ive had my turbo polished for several years. It still looks good. I just hit that biotch every so often with some mothers metal polish. When it gets bad ill take it to a guy who does the polishing on Harley . But dont listen to me.
Old Feb 26, 2002 | 08:30 PM
HidPerf's Avatar
Default Re: Chrome compressor housing... (SO3Burner)
You can buy some "chrome" high temp paint from Auto Zone and it will look GREAT!!
Just kiddin'
fragmare
Jul 25, 2017 06:26 PM
chicken head
Jun 20, 2006 06:16 PM
AndyFloyd
Nov 7, 2005 09:23 AM
SpeedDreamz.com
Mar 30, 2005 03:38 PM
austrian type-R
Apr 14, 2003 02:56 AM
