Can i get a wastegate actuator set for 6psi???
New User
i have a custom T25 that is set around 9-10psi. i have the door cracked open so i can be able to boost to 6psi, doing this i don't get a good feel for the turbo. so i was wondering if i can get a custom 6psi actuator that will bolt right on to the T25?the 2nd alternative was maybe getting a new manifold w/ a external wastegate? but first i want to see if i can get that 6psi actuator somewhere. can anyone help me. you all can IM me on AIM with suggestions. thanks guys
-jeff
AIM: jepoy08
-jeff
AIM: jepoy08
Re: Can i get a wastegate actuator set for 6psi??? (jmad08)
if u have an hf manifold like im guessing... have a machine shop open up the 02 sensor hole...have a skilled welder weld a tube+deltagate flange there..get a deltagate..5-7psi spring...have a o2 sensor bung welded to downpipe instead...there u go. oh yea..welding cast itself and to other metals aint no joke..welder must be pretty skilled
[Modified by JaeOne3345, 3:22 PM 2/27/2002]
Reilly
08-30-2005 07:09 PM
DsMWookie
Welding / Fabrication
10-21-2004 03:27 PM
