Running 8psi
Old Feb 23, 2002 | 11:58 AM
BoostedSi's Avatar
Default Running 8psi
Do i need a boostdependent fmu running 8psi? My fuel setup is this: rc 440cc injectors, apexi vafc, b&m regulator, and airtek inline fuel pump. Can i run 8psi safely with this setup? thanks
Old Feb 23, 2002 | 12:03 PM
D-SPEED's Avatar
Default Re: Running 8psi (BoostedSi)
you have 440s already, FPR, and a fuel pump....get hondata
Old Feb 23, 2002 | 12:06 PM
immortal's Avatar
Banned
Default Re: Running 8psi (D-SPEED)
Hondata
Old Feb 23, 2002 | 12:07 PM
BoostedSi's Avatar
y does everyone just go around saying get hondata. I know i need hondata. I dont have the money yet. I was just wondering if i could boost reliably at 8psi with that fuel setup.
Old Feb 23, 2002 | 01:01 PM
2000_Civic_Si's Avatar
Yes you will need the FMU! It will raise the fuel pressure when you go into boost. If you just run a base fuel pressur eand run 8psi. you can kiss you motor good bye. Also, when you get the money, I would suggest getting Hondata.
Old Feb 23, 2002 | 01:19 PM
*Boostwerks*'s Avatar
Yes I would get the FMU. Get a lower ratio though, like a 4:1. Then use the VAFC to lower the fueling as the boost increases. If not I think it will be very rich during boost. If you have the VAFC setup correctly, it should run reliabley.
Old Feb 23, 2002 | 01:22 PM
BoostedSi's Avatar
Default Re: Running 8psi (Bryson)
Where can u get the smaller discs from? I have a 12:1 fmu that came with the kit but i have no clue where to get the smaller discs. Thanks
Old Feb 23, 2002 | 01:26 PM
What kind of FMU is it? Vortech has ones that have a 4:1 ratio.
Old Feb 23, 2002 | 01:29 PM
BoostedSi's Avatar
Its vortech. I could've sworn its was a 12:1 disc tho. I could be wrong. Wut disc do the drag3 kits come with? And also can u buy just the discs if i did have a 12:1?
Old Feb 23, 2002 | 02:06 PM
DLB1994's Avatar
drag 3 comes with a 12:1 but u can get a Recalibration Kit, 4:1 from http://www.vortechsuperchargers.com
Old Feb 23, 2002 | 09:18 PM
Default Re: Running 8psi (DLB1994)
Hey I just read your sig. Do you have stock internals? how much boost ya running? What fuel managment do you have with the NOS?
Thanks
Old Feb 23, 2002 | 09:38 PM
DLB1994's Avatar
Thanks
i got two motors but right now i got my stock one in and i run 10psi daily
and 15psi when i race and i do this on a stock motor and i run 450cc with inline
fuel pump safc and JR fmu 5:1
i have not sprayed it yet but am going to when i put it on the dyno so i can make sure am running really rich before i spray i don't trust an air/fuel gauge that much and tune the AFC for when i spary
and my nitrous is controlled by my MSD setup
am getting a full garrett T4 or 60-1 before u put my built motor in
Sassafrass
Mar 3, 2004 11:14 AM
Bictorious
Feb 16, 2004 09:36 AM
Bictorious
Jan 27, 2004 12:18 PM
BoostedSOHC
Apr 11, 2003 10:46 PM
R-1303
Mar 5, 2002 07:42 AM
