What will this setup put down at 20psi?
Old Feb 21, 2002 | 12:05 PM
94SupraTT's Avatar
Default What will this setup put down at 20psi?
1.8 B18C1 DOHC VTEC , 9:1 JE pistons, CROWER rods, CROWER turbo cams, reversed valve springs, STR blockguard, polished/ported head, shaved intake valve ports, MSD SCI ignition, MSD coil, MSD roto cap, APEXI N1 exhaust, TOUCAN spark wires, 6-puck clutch kit, VORTECH blow-off valve, VORTECH FMU, MSD high volume fuel pump, TURBONETICS external wastegate, REVHARD upgraded intercooler, and a REVHARD T3/T4 STAGE II TURBO KIT.
Old Feb 21, 2002 | 12:07 PM
b18bturbo's Avatar
Default Re: What will this setup put down at 20psi? (94SupraTT)
its called you wont have a motor left. I would highly reccommend you change your fuel solution and then try 20 psi. IT will be alot better.
Old Feb 21, 2002 | 12:13 PM
DaveF's Avatar
Default Re: What will this setup put down at 20psi? (b18bturbo)
reversed valve springs??...str block guard???
why not get the block sleeved?
Old Feb 21, 2002 | 12:15 PM
boost killz's Avatar
New User
Fuel solution is definitely no good and also consider upgrading the wastegate to a Tial or HKS. And possibly that high consider a bigger IC. With those factors resolved should put down in the range of 350 to 380 whp at 20 psi, depending on tuning but thats my guesstimate from similar setups as yours.
Nick
Old Feb 21, 2002 | 12:32 PM
94SupraTT's Avatar
LOL! Its not my setup Its a local honda that claimed at one point he was going to blow away every import in the area. Well He's been working on his car for a while and I have yet to see anything. Just wanted to know what I should expect once it is up and running. There are a few low-mid 12sec hondas.(12.07-12.7 to be exact) in my area, I think he neesd to worry about putting down numbers comparable to them, before running off at the mouth The one that ran a 12.07 will be in the 11s this season, his car is NUTS!
Thanks for all the info guys!
[Modified by 94SupraTT, 9:34 PM 2/21/2002]
Old Feb 21, 2002 | 12:41 PM
DaveF's Avatar
Default Re: What will this setup put down at 20psi? (boost killz)
Nick
i would hope it be alot more hp's than that...
check this(it put out 340hp @14psi on 116)
started as a stock type r engine
golden eagle sleeves
81 mm je 9.0:1 pistons
crower rods
arp's
stock head gasket
bone stock cyl head
310's
afc
rev hard stage II kit
full 3 inch exhuast
tial 40 mm wastgate
it ran 11.9 @120 with a "shitteee" driver in a completly stock type-r(meaning full interior) with stock supension and a set of 24.5x 9 slicks
[Modified by turboDA, 1:43 PM 2/21/2002]
[Modified by turboDA, 1:44 PM 2/21/2002]
b20forlife
Jun 26, 2009 04:32 PM
MVCIVIC
Mar 11, 2008 07:38 PM
GOIN V8 HUNTIN
Oct 5, 2006 10:08 PM
GOIN V8 HUNTIN
Sep 26, 2006 10:26 AM
CRX SiR T
Aug 1, 2003 01:50 PM
