line locks
Old Feb 25, 2002 | 08:27 PM
AlphaKennyWun's Avatar
Default line locks
What good does this serve for drag racing?
Old Feb 25, 2002 | 09:41 PM
shamoo's Avatar
Will you make something up for me please?
Default Re: line locks (SO3Burner)
Forgive my limited knowledge....but this is what I heard from my Mustang/domestic friends.
We can do burnouts by simply pulling the ebrake and letting it rip. RWD's can't do that cuz that would lock the rear tires and nothing would spin.
A line lock, I was led to believe, is something that makes the ebrake lock the front tires instead. Basically it can lock any combination of wheels.
Am I right, guys?
Old Feb 25, 2002 | 09:44 PM
1fstevo's Avatar
New User
Default Re: line locks (shamoo)
sounds right i think.
Old Feb 25, 2002 | 09:58 PM
rjardy's Avatar
Default Re: line locks ([Evo]Hybrid)
no here i will explain...
A line lock works like this, there is a soleniod installed in the brake line that goes to the front brakes before it splits off to each front caliper, now when you are staging you will step on the brake (hold it) and then activate the soleniod that then traps the pressure going to the front brakes. You then relaese the pedal and there is no pressure gong to the back brakes , only the front holding the caliper closed, thats it!!!
Old Feb 25, 2002 | 10:31 PM
93LSivic's Avatar
Default Re: line locks (rjardy)
Yep that about sums it up. Had one on my first hybrid -- a small block 350 powered chevy S10 pickup. Had a momentary switch hooked to the floor ratchet shiter. Basically does the soloniod thing, but you hold the button and pump the brakes so a lot of pressure holds the front brake calipers closed. Do your burnout and at high RPM let go of the button and rip the rest of the burnout.
Lots of fun to screw around with at redlights when theres a couple hotties on the corner next to you!
Old Feb 26, 2002 | 12:46 PM
boosted3g's Avatar
Default Re: line locks (93LSivic)
Your looking at major work on a Honda being that the proportioning valve works diagonaly not front to rear. You would have to do some major rerouting of the brake lines to get it to work and it would definantly effect everyday driving. Just use the E-brake
Old Feb 26, 2002 | 12:49 PM
jinxproof99's Avatar
New User
correct. also allows you to build boost on the line. great for launching. you will see this device on many drag cars in the near future. and probably on mine too.
[Modified by jinxproof99, 4:55 PM 2/26/2002]
Old Feb 26, 2002 | 02:03 PM
D-Man's Avatar
Default Re: line locks (boosted3g)
aint that major,pretty easy actually,you just have two line locks for each line running to the rear brakes,definitly DOES NOT effect everyday driving at all
Old Feb 26, 2002 | 03:11 PM
Sinitron's Avatar
Default Re: line locks (D-Man)
Remember... dont use it with ABS
2khb
Suspension & Brakes
May 27, 2014 03:25 AM
K20EF8Dx
Jun 17, 2013 05:04 PM
karmadhi
Apr 26, 2008 06:32 PM
dmotoguy
Oct 2, 2003 04:44 PM
