My set up so far... Any Reccomendations on what else???
Ok.. Here goes.....This is what i have done so far for my JDM B16 thats going in the rex i just bought.
~Port & Polish
~3 Angle Valve Job
~Gasket Matched
~Balanced Crank assembly (crank, flywheel, pressure plate, all bolts)
~JE 9:3:1 Pistons
~Eagle H Beam Rods
~99-00 Greddy Si Kit
~Hondata Stage2B
~DSM 440 Injectors
~99-00 TB/manifold
Im putting the engine back together little by little. But there are some things i was wondering if they were ABSOLUTLY NECCESSARY....Theres alot more of things i got but i listed the more important stuff.
Should i get?
1. ARP Head Studs
2. Block Guard (which is on backorder)
3. Valve Springs and Retainers
Im planning on running 14 psi for track events and on occasional full moons
But other than that im going to run 8 psi daily. Im going to run the redline at 8 K, no more than that....
Thanks for your input
~Port & Polish
~3 Angle Valve Job
~Gasket Matched
~JE 9:3:1 Pistons
~Eagle H Beam Rods
~Hondata Stage2B
~DSM 440 Injectors
~99-00 TB/manifold
Should i get?
1. ARP Head Studs
Re: My set up so far... Any Reccomendations on what else??? (SUMORex)
1. ARP Head Studs
2. Blockguard IMO I'd want to avoid it and if you can afford it get Godzilla Sleeves
3. Valve Springs and retainers not sure.....I'd just get ITR valve springs, ITR intake valves, SS exhaust valves, and some portflow retainers
Now this this just what I'd do....it's up 2 you though....depending on what you want.GL
-Trung
-Trung
Re: My set up so far... Any Reccomendations on what else??? (Projekt20)
thanks for you input
my goal is to get about 300 HP...
Im planning in running about 15 track and occasionally on the street, but other than that im planning on 8 psi daily. . .
New User
looks good!
if/when you need any tuning man, let me know; i've got my wideband o2 meter now
-Xerxes
-Xerxes
