Help with fuel system
Old Feb 22, 2002 | 07:48 AM
cornbread's Avatar
Default Help with fuel system
I’m looking for some suggestions on exactly what i should get interims of upgrading my fuel system? You can look in my sig and see my current setup.
Old Feb 22, 2002 | 07:58 AM
DIRep972's Avatar
Smarter than you
Default Re: Help with fuel system (smokeeeLSR)
depends how much boost u wanna run.. With your set up Id go for some 750cc injectors.. good for all the boost you will probably ever want to run.. if u dont have a fuel pump, get one of those.
Old Feb 22, 2002 | 08:03 AM
cornbread's Avatar
Default Re: Help with fuel system (DIRep972)
I'm goanna be running 15psi at the most, but you never know i heard boost is addictive
Old Feb 22, 2002 | 08:18 AM
DIRep972's Avatar
Smarter than you
15psi is the most your gonna run on pump gas ever so i think u would be fine.. I dont know of any people using hondata to control injectors larger then 750 so u may wanna find out how big u can go with the hondata..
Old Feb 22, 2002 | 08:19 AM
rtype11's Avatar
holley intank 255LPH FI # 12912 or 12906 forget which on it is, -8line aeromotive FPR, paxton is the same, any big *** filter, AEM rail, and a crap load of AN fittings, go for earls fittings they are MIL spec and just as good quality but a little cheaper.
or go Aeromotive inline or big bosch. woops just noticed your setup, what kind of fuel pressures do you run, my suggestion may not work unless you have big injectors and standalone.
[Modified by rtype11, 12:20 PM 2/22/2002]
hatchback
May 20, 2003 09:00 PM
SweetChin
Mar 31, 2003 02:33 PM
magicwand
Aug 25, 2002 09:31 AM
riot
Feb 10, 2002 11:18 AM
thequickest GS-R
Dec 29, 2001 09:38 AM
