need help on oil return line on greddy turbo
Can anyone help me,Im loooking to upgrade my oil return line on my greddy turbo(92-95 civic kit) to earls fittings and stainless braided line, I did a search on honda-tech but could only find the info for t3 turbo housing, does anyone know which fittings i need and especially the flange that goes on the td04 turbo housing, heres what i want to do but this is for a t3 turbo https://honda-tech.com/zerothread?id=67146
Re: need help on oil return line on greddy turbo (crxnug)
I don't have an answer to your question....sorry, but I do have a question about your turbo. which turbo kit did you buy and did it come with a blow off valve? Thanks
Re: need help on oil return line on greddy turbo (fastestdriver)
i got the greddy 92-95 civic kit for my crx zc, i doesnt come with a blowoff valve or intercooler
New User
-Xerxes
New User
im actually wondering the same question
the rubber oil return tube just doesnt cut it for me
Re: need help on oil return line on greddy turbo (RoaringTurtle)
I think the best thing would be to get a steel -8 weld fitting and have it welded to the drain flange (after you cut off the nipple). Then all you need is to weld an -8 weld fitting to your pan and connect it with an -8 hose.
wouldnt it work to just tap out the hole?? and then you can run your -10 AN fitting, or whatever you decide to use into the tapped out hole on the turbo?? or would that not work??? I am in the process of buying the dame turbo and I am going to have to know the same answer myself!!!
