NPT and BSPT explained.
Old Feb 21, 2002 | 10:18 AM
mercury's Avatar
New User
Default NPT and BSPT explained.
I'm sitting here with my McMaster-Carr catalog and found the section describing the difference between these two kinds of pipe thread.
National Pipe Taper (NPT) threads are most widely used in North America. The distinguishing characteristics are that they have flattened peaks and valleys with the valley angle being 60 degrees.
British Standard Pipe Taper (BSPT) threads are the European equivalent to NPT threads. The peaks and valleys are rounded and the valley angle is 55 degrees.
Pipe size, Pipe OD, threads per inch NPT, threads per inch BSPT:
1/8", 0.405", 27, 28
1/4", 0.540", 18, 19
3/8", 0.675", 18, 19
1/2", 0.840", 14, 14
3/4", 1.050", 14, 14
1", 1.315", 11.5, 11
So in a nutshell, I hope this is enough information to discourage people from jamming NPT fittings into their Honda blocks!
Old Feb 21, 2002 | 10:22 AM
Giuseppe's Avatar
Default Re: NPT and BSPT explained. (mercury)
the back of the block is 1/8 bspt...(i know that)
how about the hole near the vtec solenoid on a
b series VTEC head...is it the same ..?????
thanks much.!
Old Feb 21, 2002 | 10:46 AM
bigTom's Avatar
Default Re: NPT and BSPT explained. (Giuseppe)
im not sure exactly what it is... but is is NOT a tapered plug
Old Feb 21, 2002 | 02:26 PM
Xerxes's Avatar
New User
Default Re: NPT and BSPT explained. (Tom)
so does anyone know why a 1/8" BSPT male will go into a 1/8" NPT female no problem? It makes sense to me that it doesn't work the other way around but I can't figure out why it does work this way...
-Xerxes
Desir Performance
Welding / Fabrication
Jun 16, 2007 09:41 PM
Diyracing2
Jan 16, 2007 03:48 PM
Want2race
25
Jul 21, 2006 05:10 PM
redzcstandardhatch
Dec 15, 2005 06:13 AM
Etylorcen
Mar 20, 2002 11:20 AM
