primary 02 Bad?
Old Nov 11, 2002 | 11:32 AM
FredoSP's Avatar
Default primary 02 Bad?
Hey guys I got the Greddy Kit and the famous blue box. We all know that it runs rich as heck, but Ive only been boosting around one month, the car does have almost 60k miles on it. Anyways I got CEL 1 today, Primary O2 Sensor short or Bad. Could this be the ned result of a car with 60k miles with of gunk on the O2 sensor + Greddy Blue Box 11.50 Richness = Burned out the 02?
Correct my if I'm wrong, but isn't the primary O2 sensor in the downpipe?
I guess its time for me to get a new one, anyone got a used one for a 99-00 Si?
Comments or suggestions?
Thanks in Advance!
Old Nov 11, 2002 | 01:19 PM
falcongsr's Avatar
What is this crap?
Default Re: primary 02 Bad? (FredoSP)
hmm thats possible..
u have air/fuel meter right?
as the o2 sensor goes bad, it will osciallate slower and slower at part throttle.
have you noticed this? i checked it that nite actually and it was oscillating ok i think.
Old Nov 11, 2002 | 01:26 PM
FredoSP's Avatar
Default Re: primary 02 Bad? (falconGSR)
hmm ill have to check tonight, I mean I can get one for under 100.00 bucks but ya know, 100.00 here and 200.00 there, it adds up.
I mean I got the secondary one working, so I'm sure this isnt bad to drive like this, right?
Old Nov 11, 2002 | 01:43 PM
falcongsr's Avatar
What is this crap?
no kidding
well...i dont think the 2nd one actually provides feedback for fuel trim, i think it just is for calculating catalyst effeciency. i would be careful.
definitely check and see how the autometer responds tonite, and reset the ecu and see if it changes when the CEL comes on.
it could be that the autometer wiring / grounding could be causing some 'abberations' on the o2 signal line, causing the CEL.
but if you're boosting often, then running hella rich might have mucked up the sensor yes.
Old Nov 11, 2002 | 01:47 PM
DeepSi's Avatar
Tell me about it
i think he is right
Yeah if you are always running rich you can kill the sensor.
-deepsi
Old Nov 11, 2002 | 01:56 PM
FredoSP's Avatar
Thanks guys Im gonna see if I can get one just to be on the safe side, ill try the thing with the Autometer tonight
Old Nov 11, 2002 | 03:08 PM
Arturbo's Avatar
Better than steak
25 Year Member
Reset the computer again and see what happens.
Old Nov 11, 2002 | 03:17 PM
Prod's Avatar
Default Re: primary 02 Bad? (Arturbo)
You can also try cleaning up the sensor, make sure the vent holes near the tip aren't all clogged up...if they are you can clean em out with a toothpick just be careful
Old Nov 11, 2002 | 03:44 PM
FredoSP's Avatar
I just did that at work, I'll keep and eye on it.
P.S. Art where are the pics from the race we went to on Sunday?
Old Nov 11, 2002 | 04:14 PM
Mr. Vapor's Avatar
yes it is possible to fry a primary 02, i know cause i did it lol.
with such a rich set up, you'll nuke that o2 sensor. i repalced it with another factory one and my problems went away. $100....are you sure its a proper 4 wire 02 sensor? that seems kinda low
Old Nov 12, 2002 | 02:16 PM
FredoSP's Avatar
Okay Art, so far so good, I'll be keeping an eye on it ... Hopefully I should have Hondata up and working alittle after Xmas
duh blacksheep
Jun 21, 2005 06:05 PM
duh blacksheep
Jun 20, 2005 03:07 PM
hondave
May 2, 2004 09:36 PM
speedymon
Mar 2, 2004 02:33 PM
ITR 2K
Feb 2, 2002 11:25 AM
