boost guage problems
Old Nov 11, 2002 | 07:12 AM
B18C-RnVA's Avatar
New User
Default boost guage problems
when i start my car the boost guage goes down to 20vac, which is correct, but when i start driving and take it up to 4K RPMS..my boost guage went down to 30vac, then when i cut the car off it goes to 0..someone help...i just installed teh boost guage hour ago
Old Nov 11, 2002 | 07:20 AM
falcongsr's Avatar
What is this crap?
Default Re: boost guage problems (B18C-RnVA)
with the pedal to the floor it should go to 0 vac.
at 4000rpm and you let off the gas completely it should go below 20 vac in most cars.
Old Nov 11, 2002 | 09:14 AM
Doodoo's Avatar
Default Re: boost guage problems (falconGSR)
If you are in gear coming down from 4000 RPMs it will dip down below 20vac.
Sounds like normal operation.
Old Nov 11, 2002 | 09:24 AM
RAWB's Avatar
My car will drop to 25Hg sometimes, 30Hg is a really strong vacuum- that's okay(when your off the throttle, right?)
That is normal-car's off- No vacuum or boost = 0.
Old Nov 11, 2002 | 09:43 AM
B18C-RnVA's Avatar
New User
Default Re: boost guage problems (integracon)
hold up..i think i explained it wrong...when im giving it gas its goes up to 10vac...
i wont go above 0vac when im reving to 4K or 5K ...its like im not making boost..i can hear the turbo spooling and everything...oh well im glad its not making anyboost until i get that dam inline fuel pump
Old Nov 11, 2002 | 09:50 AM
RAWB's Avatar
Sounds like you have a leak. Check your intake/IC piping and vacuum lines.
Had that problem too
Old Nov 11, 2002 | 09:51 AM
Doodoo's Avatar
oh.
Tee it off your FPR. Or make an individual source(best way).
Old Nov 11, 2002 | 12:03 PM
Jared's Avatar
did you tee it off the map sensor?
Old Nov 11, 2002 | 01:32 PM
B18C-RnVA's Avatar
New User
Default Re: boost guage problems (Jared)
no i didnt tee off from the map sensor.
bads2k
Jun 8, 2011 05:32 AM
pjr710
Jan 5, 2009 11:15 PM
vy3tnamezz
Nov 6, 2008 02:11 AM
teamredline9k
Dec 16, 2006 06:32 PM
civiclx97
Jun 15, 2005 08:06 PM
