serious problem here, head clearance!!!!!
Old Nov 10, 2002 | 08:55 AM
turboex's Avatar
Default serious problem here, head clearance!!!!!
ok here the deal, i have a b20 block, gsr head that was purchased as a whole. It is already sleeved. Well i ordered 9to1 compression pistons from edyne and put them on the crower rods that also came with the engine. when i turn it over by hand. (just the bottom end assembled here) the sides of the pistons come up over the side of the sleeves/block surface. As if they are too tall. Not the center, the sides. and on the gsr head it clearly mates up flush with the block, but now im sure the pistons wont complete there upward travel without hitting the head. This makes me believe the block or head has been milled a good bit. Now the engine came with a copper think *** head gasket tats is all nasty. so i guess heres the options. 1: buyy a thicker copper head gasket and have it borred to match the size on the new pistons (motor was bored out after purchase) or 2: have the tops of the pistons plained of to match the head. any ideas?? thanks
Old Nov 10, 2002 | 09:21 AM
falcongsr's Avatar
What is this crap?
Default Re: serious problem here, head clearance!!!!! (turboex)
i would talk to larry, he might have some better options for you, or some pistons with higher wrist pin placement.
Old Nov 10, 2002 | 10:39 AM
wHOAlly's Avatar
are they they right rods?
Old Nov 10, 2002 | 11:32 AM
turboex's Avatar
Default Re: serious problem here, head clearance!!!!! (AkumaY)
yes they are the right rod, ill call larry tomorrow, and ask him. chances are we will go with acopper head gasket to resolve the issue, thanks for the input
Old Nov 11, 2002 | 06:59 AM
HybridKOOP's Avatar
Default Re: serious problem here, head clearance!!!!! (AfroPuff)
If the head of block isnt level, get that fixed. Otherwise it wont seal as good and u really dont want your head sitting at an angle.
Old Nov 11, 2002 | 07:11 AM
Prod's Avatar
Does this have absolutely nothing to do with what the original dude asked or is it just me ?
Old Nov 11, 2002 | 07:14 AM
falcongsr's Avatar
What is this crap?
Default Re: serious problem here, head clearance!!!!! (Prod)
its not just you.
but be glad afropuff isint bringing the hammer down every other sentence now.
Old Nov 11, 2002 | 11:37 AM
turboex's Avatar
Default Re: serious problem here, head clearance!!!!! (falconGSR)
lol yeah thats true i never said the block or head was crocked. but thanks for the input man. Some guys! LOL
Old Nov 11, 2002 | 11:43 AM
b18bturbo's Avatar
measure the distance you have that the pistons stick out it should be somewhere in given range. Now all you need is to get a customer gasket from cometic. that is slighly larger. so if you have gap of .029sticking out then you would need something like .048 gasket. larry usually has them if you need them i have them as well.
Christopherian1982
Feb 26, 2009 05:42 AM
wreckedagain
21
Dec 15, 2005 12:19 PM
DB2#308
May 17, 2004 11:54 PM
YellowR2000x2
Sep 24, 2003 12:23 PM
