What modifications needed to make a 00-01 B18C1 Teg kit fit into a 99 Civic EX.
Re: What modifications needed to make a 00-01 B18C1 Teg kit fit into a 99 Civic EX. (AresB18C1Turbo)
with a B series motor? I hope
You will prob have to make minor changed to the IC piping and DP. The Civic and Intergra are pretty much the same when it comes to going the piping.
Re: What modifications needed to make a 00-01 B18C1 Teg kit fit into a 99 Civic EX. (2K_TEG)
Of course with a B-Series motor. I wouldn't be Ares B18C1 Turbo if I had a D-Series. So piping is pretty much good to go then? Minor changes to the DP? Would I have to have it extended or shortened?
to you too...
check this out....https://honda-tech.com/zerothread?id=330629 looks like the DRAG piping for both is the same.
The DP might be as well, I am not sure. I can tell you that whatever mods are needed are going to be minimal.
