no downpipe..
Old Nov 10, 2002 | 02:16 PM
B18C-RnVA's Avatar
New User
Default no downpipe..
right now i have my turbo hooked up and everything but no downpipe..so i was driving it home( cause the hobby shop closed) and i have stock injectors with a FMU 12:1 disk..and when i try to give it gas it just bogs down and and stutters like its getting to much fuel...what should my fuel settings should be according to fuel pressure guage..i think mine was at like 60psi
Old Nov 10, 2002 | 02:41 PM
Loco Honkey's Avatar
Default Re: no downpipe.. (B18C-RnVA)
No inline pump?
Old Nov 10, 2002 | 02:49 PM
B18EG6's Avatar
getting full boost?
Old Nov 10, 2002 | 03:42 PM
BoostedH23a1's Avatar
Default Re: no downpipe.. (B18EG6)
NO O2 SENSOR what out man be careful...
Old Nov 10, 2002 | 05:19 PM
B18C-RnVA's Avatar
New User
Default Re: no downpipe.. (BoostedH23a1)
i have an intank pump...should i still get a inline one??
Yeah i really need a freaking downpipe cant wait for payday, also..
Yeah i just limped her home that was all..
Old Nov 10, 2002 | 05:28 PM
sutrusu's Avatar
INLINE INLINE INLINE INLINE!!!!!!
oh, wait
INLINE!!!!!!!!!!!
Old Nov 10, 2002 | 05:44 PM
B18C-RnVA's Avatar
New User
Default Re: no downpipe.. (sutrusu)
oh shizzle. let me put that on list ...things to get on payday
Old Nov 10, 2002 | 06:17 PM
Goddamn right you should get an inline! With a 12:1 FMU, you're looking at around 130 PSI needed or you're going to be lean. Your stock in tank is good for about 70.
Old Nov 10, 2002 | 06:19 PM
Default Re: no downpipe.. (House of Boost)
they are right.
Old Nov 10, 2002 | 07:10 PM
Jared's Avatar
Just get a Walbro high pressure high volume intank pump to replace your stocker.
Old Nov 10, 2002 | 07:15 PM
D-SPEED's Avatar
Default Re: no downpipe.. (Jared)
with the FMU you should get an inline, if your running hondata or so, the walbro in tank will be sufficient
Old Nov 10, 2002 | 07:23 PM
20lb.teg's Avatar
Default Re: no downpipe.. (D-SPEED)
Just get the walbro you'll be hondata'd (if that is a word) in a short bit anyway... and dude I never even thought that your 02 sensor was in your cat and not the header.... Dude that's why you'r running like ****! That makes perfect sense, H23 you're an ok guy!!!! and a cold for you!
Later,
Sean C.
Old Nov 11, 2002 | 08:16 AM
RAWB's Avatar
Just to show you what can happen- awhile ago on a dyno run at 7psi, my inline cut out(using stock injectors, 12:1 FMU, like you) and my A/F sky rocketed to 16:1. Moral of the story- get something that can keep up with the higher Fuel pressures- inline or Higher capacity intank.
Old Nov 11, 2002 | 08:50 AM
B18C-RnVA's Avatar
New User
Default Re: no downpipe.. (integracon)
thanks guys..also i was wondering when i get hondata i wont need an inline will I?? i have 440 injectors, when i get my hondata..and until i get my downpipe i iwill run like ****..correct since my o2 sensor is in my cat?
Old Nov 11, 2002 | 10:32 AM
technine's Avatar
??? Do you have any check valves, missing link or something to limit the MAP sensor? Sounds like a MAP signal problem.
Old Nov 11, 2002 | 11:27 AM
B18C-RnVA's Avatar
New User
Default Re: no downpipe.. (technine)
yep i have check valves..oh well im getting an inline and downpipe done on friday so im good..just wont drive the car..cant afford another motor
Old Nov 11, 2002 | 11:49 AM
LJR-LUDE01's Avatar
Tony you ricer.... I tough you where done.... lol... actually hope you get that fix bro... I'll be back in the states soon.... MI4...
YellowPhoenix095
May 14, 2007 06:30 AM
SIK IN DA HED
Nov 13, 2003 08:53 AM
TurbothisLS
Sep 22, 2002 07:22 AM
deacs
Sep 5, 2002 02:14 PM
SpeedRacer00-667
Apr 22, 2002 08:45 PM
