slight ping..
Old Nov 11, 2002 | 03:33 PM
b16ahybrid's Avatar
Default slight ping..
I've noticed that i can hear a slight ping (detonation) at 5psi of boost, but it's only breif and it doesn't happen at any other boost level.Any sugestions.
I'm not runing lean because it happens when i richen the fuel mixture up, and it still happens when the weather is cold (i was thinking that it was related to the hot weather that have had all summer)
Old Nov 11, 2002 | 04:20 PM
ion_four's Avatar
Default Re: slight ping.. (b16ahybrid)
do you have stock timing? if so, you should retard it a few degrees...give more info, as well. are you intercooled? Running premium gas? what fuel set-up?
Old Nov 11, 2002 | 04:31 PM
b16ahybrid's Avatar
Default Re: slight ping.. (ion_four)
timing is set at 14 degrees. i run 92 octane, and for fuel delivery i have a holley 255lph high pressure fuel pump,vortec fmu (6:1), rc 310cc injectors,aem adjustable fpr (which is 1:1 under boost),I have the greddy intercooler.It happens even with the 8:1 fmu.
Old Nov 11, 2002 | 05:29 PM
Mr. Vapor's Avatar
might wanna go to the 8:1 disc....thats what i run with my 310s
Old Nov 11, 2002 | 05:53 PM
sutrusu's Avatar
Default Re: slight ping.. (NYb16)
are you sure that it's pinging?
get an afc is the only thing i can think of
Old Nov 11, 2002 | 05:59 PM
b16ahybrid's Avatar
What do you run for base fuel pressure? if i go with the 8:1 disc my fuel pressure will raise 9:1 because if the aem.My car runs even more rich with the 8:1.
longshot
Feb 26, 2009 07:48 PM
ekk41
Dec 19, 2007 08:51 PM
huge230
Mar 3, 2007 01:53 PM
t3b18b
Apr 18, 2006 09:16 AM
99lspwr
Aug 2, 2003 04:26 PM
