Would this be worth it?
Old Nov 10, 2002 | 06:40 PM
blufke's Avatar
Default Tell me what you think and give me some info/recommendations.
im putting together all the stuff i need to do a weekend in car "rebuild". stock pistons/rods,rings,arp rod bolts,new rod bearings,headgasket,etc. im pretty sure ill go with arp for the rod bolts, is it worth it to get JE rings over OEM when the JE are 60 bux? any particular brand of bearings i should get(acl perhaps)? is it worth it to put in some arp head studs while im at it? and my last question is about the headgasket, im considering raising the CR with a thinner one, and i can raise it to about 9.6:1 as compared to the stock 9.2:1. is it worth it? lemme know. it seems more than likely that ill get most of the stuff from 2K_TEG.
[Modified by blufke, 3:45 AM 11/11/2002]
Old Nov 10, 2002 | 10:29 PM
blufke's Avatar
Default Re: Tell me what you think and give me some info/recommendations. (blufke)
Old Nov 11, 2002 | 08:17 PM
blufke's Avatar
i will be running .45 bar to start with and all we have here is 91 octane. anyone have any opinions? im also playing with the idea of using water/alcohol injection, respond here if you want to as well:
https://honda-tech.com/zerothread?id=330356
MeathooK
Jun 19, 2008 12:35 AM
slacks
May 18, 2008 08:08 PM
KooK
Dec 9, 2005 12:16 PM
ls95hatch
15
Apr 10, 2004 06:58 PM
Aeka GSR
Apr 30, 2003 12:52 PM
