Block Guard Install
Old Nov 10, 2002 | 07:41 AM
McFly's Avatar
Default Block Guard Install
When installing a block guard, how far in should it be installed? Should it be flush with the deck or gasket surface or should it be lightly tapped in evenly about 4 or 5mm below the deck? Thanks
_______
Old Nov 10, 2002 | 09:10 AM
boosted hybrid's Avatar
Default Re: Block Guard Install (UnderFire)
Never tap the block guard in. Sand down the block guard to the point where you can easily place it into the water jacket. You want the block guard to lay a bit underneath the deck, your restricted by the tops of the coolant jackets as to how far you can actually place the guard in.
Bc3
Aug 24, 2009 04:50 PM
10SecDSM
Sep 15, 2006 08:11 AM
menkio
Jun 12, 2004 10:37 AM
sodacan33
May 2, 2004 05:53 PM
