jrsc+aem pullies
Anyone ever used them together. thinking about getting some. What would i need to change with the SC to run them? also what kind of gains can i expect?
i am guessing this is an underdrive pulley you're talking about. if it slows down the speed of the alternator then its going to slow down the speed of the supercharger. lowering your boost level.
If you wish to use AEM Tru-Power pulleys with your setup, you will need to change the belt that is provided w/ the kit. The JRSC comes with a 6PK1935 belt--you'll need a 6PK1970 belt to make it work.
It doesn't slow down the SC, the only reason the Alt. is slowed down is because the Alt pulley (AEM) is larger. It still turns at the same speed, just like the crank pulley.
[Modified by sticks, 3:50 AM 11/14/2002]
agratise
Jan 20, 2005 12:36 PM
