there are 2 nipples on my compressor housing, which one should i use for the wastegate?
EPIC TUNING
Imnot sure which one i need to use to run to the boost controller, theresone near the outlet, and one all the way where the housing thats to get bigger than the inlet pipe if you know where i mean. so which one do I use and what is the other one for? should i just use the other for the boost guage or what? ive never seen a turbo with 2 nipples onit.
Re: there are 2 nipples on my compressor housing, which one should i use for the wastegate? (rewsnae
Your not being very clear but either one should work as long as its plumbed into thw copressor housing and boost somes out if the nipple. Cap the other one off if not used.
T-RO
08-01-2003 01:28 PM
