Cooling Problem......Please help me :)
Old Nov 10, 2002 | 07:20 PM
intekragsr's Avatar
Default Cooling Problem......Please help me :)
Well i just got my car back with a new clutch in
Now my car is over heating
When driving , the temp needle goes about 3/4 up and close to hitting the red mark. I popped the hood and me upper radiator hose(fat one) was getting really fat and looked like its about to blow up.
Please, what the heck could go wrong? What are some thing I should check?
Thanks for you time.
Old Nov 10, 2002 | 07:24 PM
prophet's Avatar
Default Re: Cooling Problem......Please help me :) (intekragsr)
do you have any kinks in the hoses? If the upper looks abnormally fat, it could mean there is a clog somewhere..
Old Nov 10, 2002 | 07:26 PM
intekragsr's Avatar
Default Re: Cooling Problem......Please help me :) (prophet)
clog meaning inside one of the hoses or kinked? How can i check for clogs?
sorry i dont know anything about cooling systems
Old Nov 10, 2002 | 07:45 PM
ninesecrx's Avatar
haha...its not clogged. Sounds like the people who installed your clutch had some fun with the car maybe? That either means you have a blown head gasket or your thermostat went bad. First things first id spend 6 bucks on a stant thermostat because theres a huge huge chance that it just seized and went bad.
Old Nov 10, 2002 | 07:55 PM
intekragsr's Avatar
Default Re: Cooling Problem......Please help me :) (ninesecrx)
Thanks a lot. Also I remember a while back I didnt know(mee noob) that you had to mix the coolant with 50/50 water. does this make a difference?
Old Nov 10, 2002 | 08:05 PM
PreIudeSI's Avatar
From: California ... Beauuutiful, so cal, pwnited States
check the coolant level first (if you haven't already). then change the thermostat. Make sure the fans are coming on. make sure you don't have ne oil in your coolant or coolant in your oil. if you do, its time to make the shop change out your headgasket for free!
Old Nov 10, 2002 | 08:15 PM
intekragsr's Avatar
Default Re: Cooling Problem......Please help me :) (PreIudeSI)
what are some negative effects of over heating?
Old Nov 10, 2002 | 10:17 PM
ninesecrx's Avatar
Haha...blowing your head gasket...and it just gets worse like hurting pistons and cycl. walls, warping head and deck surfaces.
Pancho2193
13
Dec 24, 2010 03:36 PM
JdmJah
Jul 14, 2010 09:43 AM
93eh2hatch
27
Dec 19, 2007 03:02 AM
MasterCrx
May 31, 2006 03:07 PM
D C 5
Sep 16, 2005 11:00 AM
