Is this supposed to happen?
Old Nov 10, 2002 | 12:38 AM
1tyme's Avatar
Default Is this supposed to happen?
i just swapped in a b16a into my 92 cx hb. i'm running a LS transmission have i/h/e and i don't have the b16 ecu so i'm running a LS ecu and a v-afc. well any ways i started it up and i get a CEL. but i decided to race it anyways. i call my fren over and he has a 90 integra LS i/h/e and crower stage 2 cams, nothing wild. well we race over and over and come 3rd gear he just floats by me like nothing. i lowered my vtec and the best i did was pull in 1st and 2nd but come 3rd i get murdered again. is it cause of my trans? or my ecu? wats goin on?! i have a turbo setup for this motor but i might not even bother to put it, i'm frustrated.
Old Nov 10, 2002 | 01:26 AM
MiraiZ's Avatar
Default Re: Is this supposed to happen? (1tyme)
so..your turbo isnt in yet right? and you have a 92 cx and a b16a with a tranny with very long gears....and youre wondering why you getting creamed??
go to the hybrid forum and figure it out..
Old Nov 10, 2002 | 03:40 PM
1tyme's Avatar
Default Re: Is this supposed to happen? (MiraiZ)
would you recommend throwing on the turbo?
Old Nov 10, 2002 | 03:48 PM
highmilehatch's Avatar
I would recommend you throw on a b16 trans
Old Nov 10, 2002 | 03:54 PM
boosted3g's Avatar
Default Re: Is this supposed to happen? (highmilehatch)
it sounds like when you sent to the LS ecu you didnt wire up something to activate the vtec. You are probably throwing a code 22 if i remember correctly. If you did wire it in well then your tuning is just way off.
PM-Performance's Avatar
yea man , chuck that ls tranny and put in the b16 or some kind of tranny from a vtec motor. you need the shorter gearing .
Old Nov 10, 2002 | 04:00 PM
AB16A2T's Avatar
Default Re: Is this supposed to happen? (boosted3g)
Do LS Ecu's even have the ability to activate Vtec... LS engines are Non-Vtec..
Old Nov 10, 2002 | 04:04 PM
Finest's Avatar
Wait. You have a B16a. Plus an LS ECU?
Am I missing something here? What are you using to activate the VTEC?...the VAFC? (didn't know you could do that?)
BTW, find out what the CEL is and we can help you diagnose the problem.
Old Nov 10, 2002 | 05:22 PM
Jared's Avatar
Default Re: Is this supposed to happen? (Prelude_RCR)
the problem is the ls computer with a freaking 6800 rev limiter, no vtec fueling or timing and you using the vafc to activate vtec, that is the main problem. the other is the long geared trans.
Old Nov 10, 2002 | 05:26 PM
sutrusu's Avatar
Default Re: Is this supposed to happen? (Jared)
this has to be a joke
[Modified by sutrusu, 2:27 AM 11/11/2002]
bdicustoms
Apr 23, 2003 09:42 AM
South Bay Surfer
10
Jan 22, 2003 11:57 PM
1tyme
Nov 10, 2002 08:15 PM
92HB_HB
Jan 24, 2002 07:45 PM
