Spark Knock.....
Old Nov 11, 2002 | 10:51 AM
FastechAccord's Avatar
Default Spark Knock.....
I am currently running the vafc hack on my 97 Accord. I wanted to run it NA first to get any bugs out before boosting. From 2000 rpm til about 2600 rpm i get spark knock under heavy load. I cant figure out why it is doing this. I was running -32, but now I am running -24 correction on the vafc and it still pings. Can someone help me out here?
Old Nov 11, 2002 | 10:56 AM
BlueSi2k's Avatar
Default Re: Spark Knock..... (EvoAccord)
what kind of injectors are you running? the hack is made for ~450cc injectors. If you have stock injectors you aren't doing anything but taking 32% percent of needed fuel out. If that is the case, put the vafc back to 0. If you have 450's, I would double check the wiring.
Old Nov 11, 2002 | 11:03 AM
Default Re: Spark Knock..... (BlueSi2k)
I have DSM 450s and I am positive the wiring is right.
Old Nov 11, 2002 | 11:17 AM
technine's Avatar
How far is your timing advanced? What kinda gas do you run? Also, did this happen even before you put the hack in?
Old Nov 11, 2002 | 08:25 PM
Default Re: Spark Knock..... (technine)
I have tried 93, but nothing seems to help. I am running stock timing on 0 boost and it never did this before the hack.
1.8T_EG
Dec 9, 2003 09:11 PM
b18cya
Dec 20, 2002 05:48 PM
FastechAccord
Nov 12, 2002 02:46 PM
FastechAccord
Nov 11, 2002 11:11 AM
1.8T_EG
Sep 16, 2002 12:22 PM
