Who has a 60trim t3-to4e turbo, your opinions...Dyno sheets? or plots?
wanna get a t3-t04e 60trim .63AR stg. 3 wheel.
id like to know how it spools, what psi @ what WHP u dynoed and etc...thanks
wade
wade
Re: Who has a 60trim t3-to4e turbo, your opinions...Dyno sheets? or plots? (wade)
i have that turbo on my stock LS...open DP i hit full boost around 3700rpms or so...and i made 303whp and 270wtq on my old motor (oil pump gears broke and starved the bearings of oil) so on my new stock ls i made 211whp on 6psi and 282whp on 12 psi. im hoping for 320whp or so on 15-16psi
Re: (phiberoptik)
T3 super 60 is a wonderful turbo for both spool and top end. a 300ish whp honda is ******* fast... and when it spools like a t3... You'll love it.
Matt
Matt
t3/to4e on a stock b18c1. the dips in torque are due to misfire. once plugs are replaced and regapped it should be smooth. that pull was at 9 psi. regular max rev mani.
and for some reason pic isnt working. well the numbers are 290whp and 190tq @9psi
Re: Who has a 60trim t3-to4e turbo, your opinions...Dyno sheets? or plots? (careawholelot)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by careawholelot »</TD></TR><TR><TD CLASS="quote">can anyone post pics of the turbo itself</TD></TR></TABLE>
It looks alike because the housing is the same. The wheel is a little more agressive and/or bigger I'm not sure, but i know it's both or one of the two
edit: I just linked the pic...makes it easier
Modified by adseguy at 3:20 PM 9/29/2004
Re: Who has a 60trim t3-to4e turbo, your opinions...Dyno sheets? or plots? (adseguy)
looks exactly like the one i have, thanks for the quick response , hoping to make near or more then 300 whp on stock ls cometic head gasket and arp head studs i will know by next week
I have a 60trim with a .63ar stage 5 exhaust on my dohc ZC (1.6litre built 9:1). I get full boost in 4th (15psi) at 4700rpms. In 2nd i get full boost around 5000rpms. Pulls like a freight train until 9000rpms.
liam
liam
Re: Who has a 60trim t3-to4e turbo, your opinions...Dyno sheets? or plots? (boost psycho)
nice to see a lot of people running this turbo
TSPeed Factory
Re: Who has a 60trim t3-to4e turbo, your opinions...Dyno sheets? or plots? (integranator)
here are a few pics of my T3/T4e 57/63 snail:
notice how the turbo up above has a 4 bolt discharge flange. mine comes with a 5 bolt.
b18_ef_hatch
05-20-2014 09:07 PM
