Greddy Turbo Kit...
Old Sep 15, 2004 | 08:01 PM
h22acivicman's Avatar
Default Greddy Turbo Kit...
Hey I Just installed a Greddy Turbo Kit On my D16z6 I looking for 10lbs of Boost But its Only reaching 5lbs and when I try to set the emange over 5lbs it resets back to 5lbs of boost can someone helpe me out with its....I am New to this so Dont Give no Rude Comments...
Old Sep 15, 2004 | 08:03 PM
Default Re: Greddy Turbo Kit... (h22acivicman)
I have 310cc Injectors And Apexi Vtec Controller... With an Obx Intake Manifold...I would like for someone to try and help me out on this please...
Old Sep 15, 2004 | 08:50 PM
Street Ghost's Avatar
Answer: Boost Controller
It's only hitting 5lbs because that's what the spring in the wastegate is set to.
Old Sep 15, 2004 | 08:52 PM
Default Re: Greddy Turbo Kit... (JDM Ninja)
But On the WasteGate With the Screw I Took the Screw off and Made It Really Short and Connected it back.... And Made No difference.....So you think a boost controller would help greatly?
Old Sep 15, 2004 | 09:22 PM
94dxt's Avatar
mine has always been responsive to shortening the w/g arm
Old Sep 15, 2004 | 10:04 PM
If you shorten the wastegate arm too much.. it will bind the wastegate spring overtime. Just get a boost controller. Manual ones are only like $40 for a Joe P MBC.
Old Sep 16, 2004 | 02:58 AM
tegon-gsr's Avatar
can you use a manual boost controller with the greddy kit? I thought you couldnt not do this and the only way to turn up the boost would be to twist the arm were the internal wastgate is.
Old Sep 16, 2004 | 03:48 AM
SOHC_MShue's Avatar
Default Re: Greddy Turbo Kit... (tegon-gsr)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by tegon-gsr &raquo;</TD></TR><TR><TD CLASS="quote">can you use a manual boost controller with the greddy kit? I thought you couldnt not do this and the only way to turn up the boost would be to twist the arm were the internal wastgate is.</TD></TR></TABLE>
why wouldn't you be able to do it? The internally wastegated turbo in the greddy kit works the same way any other internally wastegated turbo does. You just run the boost controller inline with the vacuum source and the wastegate actuator.
Old Sep 16, 2004 | 05:25 AM
tegon-gsr's Avatar
Default Re: Greddy Turbo Kit... (SOHC_MShue)
i.c im going to save up then and get the greddy boost controller
avotegra
May 22, 2007 12:31 PM
mogz
Dec 5, 2003 10:38 PM
TurboLude00
Oct 25, 2002 10:10 AM
madman604
Sep 16, 2002 02:24 PM
clean
Oct 18, 2001 11:16 AM
