SC34+D16Z6=???????? anyone running one on their d-series?
well if you are please post experiences, dyno graphs, and comments. what can i expect spool time to be on a d16z6 9.2:1 comp ratio?
thanks
btw: i have the .60/.63 57 trim
Modified by rextec at 7:30 AM 10/18/2004
thanks
Re: SC34+D16Z6=???????? anyone running one on their d-series? (rextec)
What are your power goals? I will be using an SC50 with my setup, which is a little bit smaller.
Re: (rextec)
300whp should be easily attainable with 9.2:1 C/R on pump. I am aiming for 300whp on pump with 10:1 C/R. For only that much power you might want to look into the SC50, it would spool a little faster and is capable of somewhere around 400whp.
thanks for the reply! i have a new sc34 that i had for an LS but i changed my mind and im going d-series ninja! how much boost on 91 oct. do you think ill need to get to 300 whp on a built z6?
Location: east coast performance and tuning, jacksonville, nc
Re: (RyanCivic2000)
i made 265whp on 14psi im also trying for 300 on pump gas. next well be 16psi on the 550 injectors.
Re: (UJLSMoFo)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UJLSMoFo »</TD></TR><TR><TD CLASS="quote">i made 265whp on 14psi im also trying for 300 on pump gas. next well be 16psi on the 550 injectors.</TD></TR></TABLE>
what turbo were you running?
M.A.R.C.
02-22-2004 09:34 AM
