Calling All Tuners
Old Sep 16, 2004 | 12:56 AM
g2_boosted's Avatar
Default Calling All Tuners
Im Gonna be street tuning my Turbo Civic and I am using the PLX wideband system and using the VAFC hack. Whats should i try to tune the air/fuel mixture to in order to get the best gains. So pretty much whats the best air/fuel mix
Thanks
Old Sep 16, 2004 | 04:07 AM
Boltz's Avatar
Default Re: Calling All Tuners (g2_boosted)
id keep it a hair under 12:1 under boost.
Old Sep 16, 2004 | 04:47 AM
underpressure02's Avatar
Default Re: Calling All Tuners (Boltz)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Boltz &raquo;</TD></TR><TR><TD CLASS="quote">id keep it a hair under 12:1 under boost. </TD></TR></TABLE>
And 14.7 in vacuum just cruising.
Old Sep 16, 2004 | 07:12 AM
TeamCracka's Avatar
Default Re: Calling All Tuners (underpressure02)
First thing you need to do is to get some engine management if you dont want to grenade your motor from advanced timing in boost.
2nd would be to look at the Uberdata and HomeMadeTurbo message boards to figure out what parts of the vacuum/pressure maps you need to tune to what A/F.
Just chip your ECU and run Uberedata, its $25 and you can make back cash on your VAFC.
Old Sep 16, 2004 | 09:00 AM
Alchemist's Avatar
Default Re: Calling All Tuners (TeamCracka)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by TeamCracka &raquo;</TD></TR><TR><TD CLASS="quote">First thing you need to do is to get some engine management if you dont want to grenade your motor from advanced timing in boost.
Just chip your ECU and run Uberedata, its $25 and you can make back cash on your VAFC. </TD></TR></TABLE>
Yeah, if you already have a wideband, then all you need is chipping supplies and you can run uberdata.
Old Sep 16, 2004 | 09:51 AM
PrecisionH23a's Avatar
Retard your timing via distributor (if you are obd1) about 5-6 degrees.
bOOsT-FeIn
Jul 9, 2007 09:17 AM
hatchedzex
Dec 23, 2004 10:48 AM
bikeman311
Apr 13, 2004 01:40 PM
boredracer408
Feb 16, 2004 05:30 AM
goern-R
Jul 28, 2001 02:14 AM
