Wont turn over :(
Old Sep 15, 2004 | 04:54 PM
PolyPill's Avatar
Default Wont turn over :(
I just put a new skunk 2 intake manifold, some RC 440 injectors, a Walbro 255 fuel pump, and an AEM fuel presure regulartor on my b18c1 and now I can't get it to start. It sparks and I can hear the fuel going through, but it just wont fire. I checked all the fuses and made sure everything was plugged in. Now I'm out of ideas so please help me. What else should I check?
Old Sep 15, 2004 | 04:58 PM
Jared's Avatar
Default Re: Wont turn over :( (PolyPill)
do you have anything to control all that new fuel?
Old Sep 15, 2004 | 05:01 PM
sporkcrx's Avatar
How can you hear the fuel? When it primes?
Old Sep 15, 2004 | 07:19 PM
PolyPill's Avatar
Default Re: Wont turn over :( (sporkcrx)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Jared &raquo;</TD></TR><TR><TD CLASS="quote">do you have anything to control all that new fuel?</TD></TR></TABLE>
I made a basic basemap for my hondata with the new injectors so I'd think it would at least run rough.
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by sporkcrx &raquo;</TD></TR><TR><TD CLASS="quote">How can you hear the fuel? When it primes?</TD></TR></TABLE>
With the rear seats out the fuel pump is quite loud and very noticable, can also hear it when I put my ear by the fuel pressure regulator. I'm just assuming the injectors work, I tested the voltage to them, 12v.
I have no clue how to work the fuel pressure regulator, my understanding is I should turn the nut on top to adjust it and it is all the way tight.
Old Sep 15, 2004 | 08:38 PM
h22acivicman's Avatar
I think you may have a fuel problem bud...I have the same problem on my d16z6 when i installed my new intake manifold it turn over but kepted doing it.....It may be bad o-ring on the injectors..
Old Sep 16, 2004 | 05:12 AM
PolyPill's Avatar
Default Re: Wont turn over :( (h22acivicman)
The o-rings are new with the injectors, no fuel leaks out, how do I know if that is the problem? Should I just get some new o-rings?
Old Sep 16, 2004 | 05:30 AM
I'm Not sure Thats what happen to mine I had a tiny fuel leak and it wouldnt start so i replace all the o-rings it and started right up..
Old Sep 16, 2004 | 06:46 AM
badCRX's Avatar
New User
I presume you have no fuel pressure guage?
Old Sep 16, 2004 | 06:53 AM
White Smoke's Avatar
i my honda
Global Mod
Default Re: Wont turn over :( (badCRX)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by badCRX &raquo;</TD></TR><TR><TD CLASS="quote">I presume you have no fuel pressure guage?</TD></TR></TABLE>
Ya You are allowing no fuel of way to much. The regulater should not be all the way tight OR all the way lose. You NEED a gauge
Also double check you hondata map. Do you have experience w/hondata?
Old Sep 16, 2004 | 07:20 AM
PolyPill's Avatar
Default Re: Wont turn over :( (si2die4)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by si2die4 &raquo;</TD></TR><TR><TD CLASS="quote">Ya You are allowing no fuel of way to much. The regulater should not be all the way tight OR all the way lose. You NEED a gauge
Also double check you hondata map. Do you have experience w/hondata?</TD></TR></TABLE>
You are correct sir, I have no pressure gauge, I was wondering about that. What is a decent/cheap one I should get? I think all I need to do is tap the stock fuel rail and attach it, right?
With hondata I know the basics but I don't know how to really tune, I started with the base b18c1 turbo map and changed the injector size and boost. I made one for a P30 and P72 ECU I have and they both do the same thing, although I'm not going to rule out bad ecu or bad map, but I just thought it would at least turn over.
Can I use a P72 to control an intake manifold that doesn't have the dual runners?
Old Sep 16, 2004 | 07:29 AM
93turbo16's Avatar
you can get a really nice gauge that goes off your fuel filter. like $35.00 shipped. Its B&M it fits real nice, summitt sells them. I have one, good thing to have when tuning the fuel.
Old Sep 16, 2004 | 07:42 AM
DSF's Avatar
DSF
Are you sure you have the right injectors? Are they even firing? Use a stethoscope or long screwdriver and listen to each injector to make sure. Pull the spark plugs see if they are wet. Check and make sure you are still getting spark. If all that is ok, then it's most likely your ecu map.
Old Sep 16, 2004 | 08:06 AM
PolyPill's Avatar
Default Re: Wont turn over :( (DSF)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSF &raquo;</TD></TR><TR><TD CLASS="quote">Are you sure you have the right injectors? Are they even firing? Use a stethoscope or long screwdriver and listen to each injector to make sure. Pull the spark plugs see if they are wet. Check and make sure you are still getting spark. If all that is ok, then it's most likely your ecu map.</TD></TR></TABLE>
I guess I'm not sure if the injectors are firing. How do I tell with a long screw driver? Put it in the cylinder with the spak plugs disconnected and see if it gets fuel on it?
When I pulled a spark plug to test for spark I don't think it was wet.
If the injectors aren't firing what do I do? I read there is no polarity to them and I already tested the clips with a voltmeter.
**edit: The injectors are RC 440 from wiredspeed.com, so I think they would be the right ones.
Old Sep 16, 2004 | 08:13 AM
DSF's Avatar
DSF
Get some one to try and start the car while you hold the tip of the screwdriver on the injector body and the end of the handle pressed against your ear. You should hear a solid "ticking" sound if the injector is firing.
There is no polarity, but there are high and low resistence types of injectors.
Old Sep 16, 2004 | 08:17 AM
PolyPill's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DSF &raquo;</TD></TR><TR><TD CLASS="quote">There is no polarity, but there are high and low resistence types of injectors.</TD></TR></TABLE>
This what it is exactly "RC Engineering 440cc Saturated Injector" How do I know which kind of resistence it is?
http://www.wiredspeed.com/item...=&Tp=
Old Sep 16, 2004 | 09:00 AM
IN VTEC's Avatar
RC 440cc injectors are saturated, high-impedance. Saturated = high impedance (12 to 16 ohms).
If you need a fuel pressure gauge, I can sell you my B&M one since I have another one on the car.
You can try slapping the stock regulator back on to see if it'll start.
hYbRiD EeEkAy
16
Apr 19, 2008 12:37 PM
.BigSexy
Jun 20, 2007 07:11 PM
the king.
Sep 25, 2006 05:16 PM
rexdout45
May 2, 2006 08:11 PM
lsvtecna
Mar 25, 2006 06:47 PM
