Adjustable Internal wastegate question
Old Sep 13, 2004 | 05:38 PM
beepy's Avatar
Default Adjustable Internal wastegate question
I can't figure this out.
I have a .48 compressor T3 with an internal wastegate. The wastegate is adjustable and I have it set at about 8 PSI.
Here's the problem. Today the wasgate actuator bracket became loose and I started making only a few PSI. I tightened it down, and all of a sudden I was dangerously overboosting. I kept and eye on my gauge but where I was making full boost before at about 5000 RPM, all of a sudden I was making full boost at just under 3000 RPM. I liked it, but the engine would not survive long if I let the boost climb.
I adjusted the actuator and got it back to where it was, making a max 8 PSI and full boost at 5000 RPM. So here is the question: How can I limit my boost to 8 PSI but have the spool that I experienced with the wastegate actuator too tight? Please don't say an external wastegate. I want to keep the internal gate, but am willing to fab another kind of wastegate actuator onto the turbo if that will do the trick.
Old Sep 13, 2004 | 05:46 PM
BluntMan's Avatar
Default Re: Adjustable Internal wastegate question (beepy)
try a boost controller
Old Sep 13, 2004 | 07:39 PM
beepy's Avatar
Default Re: Adjustable Internal wastegate question (BluntMan)
Okay, enlighten me on how that would work. Is there a boost controller that I can buy that will output higher pressure than is input? Because that is the only way I can see that it would do what I need.
Old Sep 13, 2004 | 08:29 PM
Bailhatch's Avatar
5000rpm for 8 psi with that turbo is ridiculous. My lawn mower could spool that .48 a/r turbine faster than that Set the internal gate for like 6psi then set a MBC at 8. Might do exactly what you are asking about.
For reference my 1.6 sohc spools the same turbine in a .63 a/r to 8psi by about 2300rpm and 11 @ 3000ish with an MBC
Old Sep 13, 2004 | 09:31 PM
beepy's Avatar
Default Re: Adjustable Internal wastegate question (Bailhatch)
Yes, I know the spool sucked. Basically the wastegate flapper couldn't be all the way seated and not overboost. I'm trying to figure out how to fix that.
Old Sep 13, 2004 | 10:10 PM
Bailhatch's Avatar
i think the MBC might work. borrow one to see how it works, if you can.
Old Sep 13, 2004 | 10:12 PM
beepy's Avatar
I guess MBC's are inexpensive enough; it is worth a try. Thanks.
grand champ
Jan 14, 2010 02:51 PM
blackcivic44
Feb 1, 2005 07:45 PM
W O T
Jan 23, 2005 09:08 PM
MooreBoost
Sep 4, 2004 07:45 AM
Broken Gearbox
Jun 8, 2003 02:12 PM
