Good turbo size for my setup?
Old Sep 13, 2004 | 12:18 PM
MooreBoost's Avatar
Default Good turbo size for my setup?
I need to know if this is turbo has good specs for my setup.
Turbonetics T3/T04e
3" Inlet
2" Outlet
.57t compressor wheel
.50 A/R compressor
.63 A/R turbine
It will be going on either a built DOHC ZC or built D16. Probably shooting for 15psi.
Old Sep 13, 2004 | 12:38 PM
Ben Huynh's Avatar
Default Re: Good turbo size for my setup? (tegunderpressure)
That turbo is a little big for a street application but should work fine.
Old Sep 13, 2004 | 12:40 PM
TurboJesse
Guest
Posts: n/a
Default Re: Good turbo size for my setup? (ben@importparts.com)
how do you shoot for 15psi?
Old Sep 13, 2004 | 12:54 PM
MooreBoost's Avatar
Default Re: Good turbo size for my setup? (Mpir3)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mpir3 &raquo;</TD></TR><TR><TD CLASS="quote">how do you shoot for 15psi?</TD></TR></TABLE>
I dont understand...
Its actually for a CRX built purely for the drag strip. Would it be OK for that? Do you mean its not OK for the street as in a good deal of lag? But that equates into better power at less boost as apposed to a smaller turbo correct?
Old Sep 13, 2004 | 02:27 PM
MooreBoost's Avatar
Old Sep 13, 2004 | 02:34 PM
mugensport9's Avatar
i think he said its big because for a small zc im sure there will be some lag issues. but in the end it should be ok.
my choice would have been a t3 .48/.42 or a super60
Old Sep 13, 2004 | 02:37 PM
MooreBoost's Avatar
Default Re: Good turbo size for my setup? (mugensport9)
How bad would the lag be?
97grnrs
Jan 29, 2007 12:27 PM
hatchinprogress
Oct 19, 2005 07:15 PM
turbohf
Mar 14, 2003 08:28 AM
cr-x si
Feb 12, 2003 04:01 PM
*Boostwerks*
Sep 9, 2002 10:01 PM
