Boost Problem need some help...
Old Sep 13, 2004 | 11:10 AM
VTECVillain's Avatar
Default Boost Problem need some help...
We recently installed a homemade turbo setup on my friend's 94 Del Sol Si with second gen JDM B16A.
Setup:
Stone Racing tubular manifold
IHI turbo from older Subaru (not sure of model) w/ internal wastegate
Mazda RX-7 Intercooler
Custom 2.5" downpipe + charge pipes
2nd gen DSM BOV
Greddy E-manage blue box
Turbo XS manual boost controller
Autometer boost gauge
I'm not too turbo savvy so I need some help with this. The boost gauge works and I've tried another one from my own car (B18C1 w/ JRSC) which I know works fine and we get the same results - Needle will not go above 0 PSI but it does read vacuum. There is a very faint idle surge at times maybe a 200-300 RPM surge. We have tried adjusting the boost controller numerous times and get the same results. When you rev the car the BOV opens and releases the air. Is there a reason why the car is not seeing boost in the manifold? Could it be a problem with the wastegate? If anyone could throw around some idea's I'd appreciate it.
Old Sep 13, 2004 | 02:53 PM
Default Re: Boost Problem need some help... (VTECVillain)
Bump it up
Old Sep 13, 2004 | 04:49 PM
Slammed90lude's Avatar
check wastegate vacuum lines?
check the lines for the boost gauge?
TravisBiggie
Mar 1, 2013 05:59 PM
twilson
Jun 8, 2009 12:24 PM
dan_w_82
Mar 28, 2006 11:37 AM
RFd15bhatch
May 24, 2005 12:27 PM
b16hybridsol
Mar 19, 2004 09:35 PM
