GSR block or LS block???
Old Sep 15, 2004 | 09:36 PM
aberkrombie's Avatar
Default GSR block or LS block???
right now i have a portflow GSR head with the combustion chambers spotfaced to a 2.0l set up and am currently tryin to decide what block would be best for my needs...should i get a gsr block and bore it to a 2.0l or run an LS?Vtec set up with the LS block bored to a 2.0l..keep in mind the sleeves and all work will be done by bensons machine....im hopin to make the 600hp mark..but at the same time want some sort of reliability...i will most likely also be spraying...possibly a 75 shot to spool the turbo...i just dont no what block to go with....any help is appreciated
Old Sep 16, 2004 | 06:18 AM
green_GSR's Avatar
Default Re: GSR block or LS block??? (aberkrombie)
I would get a GSR block over a LS block. With a LS block, you will need to drill and tap the block for the VTEC. So you'll have a much cleaner setup with a GSR block.
Old Sep 16, 2004 | 06:48 AM
Rod.'s Avatar
Default Re: GSR block or LS block??? (green_GSR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by green_GSR &raquo;</TD></TR><TR><TD CLASS="quote">I would get a GSR block over a LS block. With a LS block, you will need to drill and tap the block for the VTEC. So you'll have a much cleaner setup with a GSR block.</TD></TR></TABLE>
what are you talking about. I did ls vtec here in my garage. Benson sleeved block nothing was drill and tapped for vtec on the block. All I had to do is block the oil passage on the HEAD, get ls vtec dowel pins and slapped the head on. To get oil to the vtec head I used the golden eagle sandwich adapater.
Old Sep 16, 2004 | 06:51 AM
B18Flip's Avatar
Default Re: GSR block or LS block??? (redturbocivic)
yeah, i think if both setups are built right you can't go wrong with either. I really like the TQ that the LS bottom end gives you though
Old Sep 16, 2004 | 12:29 PM
Default Re: GSR block or LS block??? (B18Flip)
yeah i hear ya..right now i got an LS out at bensons but am thinkin of switchin it for a GSR block..but im not completely sure tho
NICOSLOW
Dec 23, 2009 05:04 AM
PphamEK
Jan 25, 2006 07:11 AM
SupaFly_Honda
Feb 17, 2004 06:40 AM
jamal-188
Apr 29, 2002 05:40 AM
