Turbo for daily driver
Old Sep 14, 2004 | 10:02 PM
blkgsr03's Avatar
Default Turbo for daily driver
whats a good turbo setup for a daily driven 96-00 civic w/ b18c swap? i wanna keep the A/C and keep it reliable as i can get. would GSR piping fit on a civic chassis? thanks
Old Sep 14, 2004 | 10:21 PM
GrayT's Avatar
Default Re: Turbo for daily driver (CiViC KiD)
On the B18C you could reliably run 8-10PSI without running into any problems for awhile, if any. This is just what I've heard, I don't think I would test it for even a second on a daily driver.
I would personally stick with 6PSI. I'm not sure about the A/C being kept or not. I do know of some pre-made kits that allow the A/C to be left alone.
Old Sep 15, 2004 | 06:43 AM
blkgsr03's Avatar
hrmm what turbo will pass smog test?
Old Sep 15, 2004 | 06:48 AM
Kal's Avatar
Kal
Greddy kit probably will.
Just make sure you don't throw away the cat.
Old Sep 15, 2004 | 07:00 AM
FOrSfEd's Avatar
Default Re: Turbo for daily driver (Kal)
the best kit for what you want would be the Greddy Kit.
Old Sep 15, 2004 | 10:09 AM
blkgsr03's Avatar
Default Re: Turbo for daily driver (FOrSfEd)
do they make bolt on kits for gsr swapped civics?
Old Sep 15, 2004 | 11:07 AM
mike1114's Avatar
Most kits can be interchangable, the piping will just need to be cut here and ther and re-welded to fit up to your application.
Most companies make manifolds that keep AC if you wish, even full-race!! On most of the ac compatible mani's you have to run an exhaust of 2.5 then flare out the piping to 3 past the AC compressor. If you want a 3 inch exhaust.
I have GSR in 97 civic. 10psi daily, pieced together turbo kit, 281whp 180tq.
EM1ly
Aug 9, 2008 05:43 AM
FuNkDrSpOt
Dec 9, 2005 02:15 PM
integra714
Jan 8, 2005 08:46 PM
blkgsr03
Oct 5, 2004 09:22 PM
Smeeg Heed
Mar 21, 2004 09:58 PM
