Hondata and irregular idle....
Old Sep 14, 2004 | 09:21 PM
Kwuaymaikrup's Avatar
Default Hondata and irregular idle....
Does anyone have this problem as well? I get massive idle surge once my car is warm, almost to the point of dying. I have tried 3 IACV's and which did absolutelly nothing. Is this a thing with Hondata? My car is fully tuned running 1,000cc injectors. If I make a pass at the track or come to a stop after driving the car idles dead solid where it should, but a few seconds later the surging begins again. I am clueless as to what this can bee.
-Ryan
Old Sep 14, 2004 | 11:13 PM
Mase's Avatar
Default Re: Hondata and irregular idle.... (Kwuaymaikrup)
probably in the tune.
Old Sep 14, 2004 | 11:41 PM
sneakypete's Avatar
Default Re: Hondata and irregular idle.... (Mase)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">probably in the tune. </TD></TR></TABLE>
I would have to agree. My car use to do the samething until I got it retuned my bitch *** mase.
Old Sep 15, 2004 | 02:03 PM
iiilgsrlll's Avatar
My car does the same thing with the AEM. Its steady when cold but once coolant temperature rises past a certain point it starts to surge. I'm pretty sure its in the tune like Mase said.
Old Sep 15, 2004 | 02:14 PM
DIRep972's Avatar
Smarter than you
gotta be in the tune. whats the a/f ratio at idle when it surges?
Old Sep 15, 2004 | 02:29 PM
iiilgsrlll's Avatar
Default Re: Hondata and irregular idle.... (iiilgsrlll)
[Don't know about his a/f ratio but mine fluctuates between 14.7 and 12.5 during the surging. I also don't have O2 feedback enabled right now so that might be causing it.
Old Sep 15, 2004 | 02:36 PM
Mase's Avatar
o2 feedback wont fix that.
the cells are probably not linear and causing surges
Old Sep 15, 2004 | 02:44 PM
iiilgsrlll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">o2 feedback wont fix that.
the cells are probably not linear and causing surges</TD></TR></TABLE>
Thanks... I'll tell Shawn that and see if he can narrow it down.
So when are you headed down to SoCal again?
Old Sep 15, 2004 | 02:59 PM
Mase's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by iiilgsrlll &raquo;</TD></TR><TR><TD CLASS="quote">
So when are you headed down to SoCal again? </TD></TR></TABLE>
Im not sure, but a lot of people are wanting me to come back
Old Sep 15, 2004 | 03:03 PM
turbo*s2k's Avatar
Im not sure, but a lot of people are wanting me to come back </TD></TR></TABLE>
yup!
Old Sep 15, 2004 | 03:06 PM
22psicrx's Avatar
could be lean, my does it if the car is running for a long period of time then it starts to lean out, its in the tune, with hondata its where the coolant temp number that can be changed. also, on normal stock honda' s with idle serges was due to a air bubble in the coolant system or somebody played with the idle screw.
Old Sep 15, 2004 | 05:06 PM
iiilgsrlll's Avatar
You should come back. I, for one, need a street tune
Well I just checked and my af ratio goes from 13 ish at idle to completely off the charts on the lean side of the AEM gauge then oscillates back and forth. It then eventually dies. I noticed this only happens after the radiator fans have cycled at least once. If the brake pedal is pushed then the surge stops.
Old Sep 15, 2004 | 07:43 PM
Default Re: Hondata and irregular idle.... (DIRep972)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by DIRep972 &raquo;</TD></TR><TR><TD CLASS="quote">gotta be in the tune. whats the a/f ratio at idle when it surges? </TD></TR></TABLE>
I am not sure, I don't have a wideband. The weather is pretty crappy here now so i guess I have till next season to figure it out
Mase, what would show up on the maps if it was in fact the tune?
Old Sep 15, 2004 | 08:43 PM
Mase's Avatar
are all the areas around the idle portion about the same pulsewidth?
Old Sep 15, 2004 | 08:54 PM
iiilgsrlll's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by Mase &raquo;</TD></TR><TR><TD CLASS="quote">are all the areas around the idle portion about the same pulsewidth?</TD></TR></TABLE>
You mean as far as injector pulsewidth?
Old Sep 15, 2004 | 08:55 PM
Mase's Avatar
yeah
can someone post a screen shot of their fuel map?
Old Sep 15, 2004 | 08:56 PM
Mase's Avatar
or send their calibration.
Old Sep 15, 2004 | 08:57 PM
h22acivicman's Avatar
Sup Mase I was Wondering You Going to be Working ON my H Block With Anthony? I was the Guy He was Tuning me civic with Last weekend...When we had all type of trouble since my motors a pos... Lol BUt I was Wondering I heard some Great Stuff about you two.
Old Sep 16, 2004 | 02:20 AM
iiilgsrlll's Avatar
Here's my map. I know for a fact I screwed up the O2 feedback target map but again O2 feedback isn't being used right now. This was tuned by Shawn Church.
http://importsports.net/Ling/WORKMAP.V1.03.cal
Just do a "Save Target As"
BDogggUT34
Jun 8, 2007 08:38 AM
B18C2_sedan
Aug 19, 2006 07:11 AM
twofive
Jan 17, 2006 04:08 PM
*Boostwerks*
Jun 6, 2005 01:39 PM
DUALSTAGE
May 3, 2002 02:41 PM
