going to build the bottom end of my d16z6 to handle just 10-12 psi what pistons should i get?/where
well im planning on building the bottom end a little bit
and i would like to know what are some good low compressoin pistons/forged rods and where to get them, im planning to throw in some arp head studs, lower compression HG, some crank bearings(what do u guys recommend for that?) ive been doing research and i know i gotta up the fuel to, i finally got a nice job smogging cars at a test only and now i can finally start building the motor for some boost any help is appreciated
Re: going to build the bottom end of my d16z6 to handle just 10-12 psi what pistons should i get?/wh
i can get you what you need with the pistons rods hg studs ect ..pm me or call
I am boosting that right now on my stock d16z6. Your wasting your money building your motor up if you only going to run that much boost.
not really cause the motor is burning oil when i acclerate i can see it, so mite as well build the bottom end
EGdriva
25
01-06-2009 09:38 PM
Black95CivicEx
12-30-2008 02:11 PM
