gsr fuel pump good for greddy turbo kit?
Old 09-15-2004, 09:44 AM
tegon-gsr's Avatar
Default gsr fuel pump good for greddy turbo kit?
I will be installing the greddy turbo kit on my gsr i will be up grading my fuel pump in a couple of weeks after but i have to get my hondata chip for base map first would it be ok to drive around using the gsr fuel pump?
Old 09-15-2004, 01:53 PM
iiilgsrlll's Avatar
Default Re: gsr fuel pump good for greddy turbo kit? (tegon-gsr)
The stock pump works just fine.
Old 09-15-2004, 03:10 PM
22psicrx's Avatar
Default Re: gsr fuel pump good for greddy turbo kit? (iiilgsrlll)
stock pump works good, just get bigger injectors later
Old 09-16-2004, 11:44 AM
vtecgsr98's Avatar
Default Re: gsr fuel pump good for greddy turbo kit? (22psicrx)
i was wondering the same thing, im throwing a code for"system running to lean". ive checked everything 4 or 5 times now and its all hooked up right. im on the blue box which should be running alittle rich. anyone else what i might be if everthing is hooked up correctly?
Old 09-16-2004, 11:47 AM
Charlie Moua's Avatar
stock pump can dish out a decent amount of power.
what whp are you shooting for? (anything above 300) i think it would be benifical in the long run to upgrage to walbro. Or else you would be shorting the life of the OEM pump.
Old 09-19-2004, 06:50 AM
tegon-gsr's Avatar
Default Re: gsr fuel pump good for greddy turbo kit? (Charlie Moua)
230-250
mike2343
02-02-2006 07:22 PM
tegrunner
01-31-2006 10:39 AM
TrueUntilDeath.com
01-25-2005 04:45 AM
boostincoupe
05-09-2003 10:33 PM
Quick Reply: gsr fuel pump good for greddy turbo kit?
