Car gets 11 psi with 5 psi spring !
I run a B18C6 with SC34 turbo, 38mm TIAL WG, 5 psi spring and Neukin equal lenght manifold, Hondata S300.
Problem is, when i WOT before vtec, WG reguls on 5 psi.
BUT, when I enter the vtec, and inside the vtec, the boost goes to 11 psi and even more if I kept the WOT...
Checked the vacuum lines, the gauge, the ecu...
Does anyone have an idea, solution or searching way ?
Re: Car gets 11 psi with 5 psi spring ! (panta83)
are you sure the wastegate is opening? Sounds to me that its not..... or your getting major boost creep/spike
Re: Car gets 11 psi with 5 psi spring ! (BoostedEG6)
Do you have a vacuum line to the top port of the WG? If you are then you're just pushing air in keeping it closed. Leave that port open.
for a start, i would recommend geting the boost cut activated on the s300 at 10 psi or so, and with such a low boost and that mani u will get creep, if u wanna fix it might as well get a 44mm wg or increase the boost a little see if it helps, borrow someones boost controller and try it.
thanks all
When i accel . Before the vtec ( 5600 ) 5 psi and then 6500 rpm it goes slowly to 10 - 11 .
I tried without vtec and it's the same thing but it goes slower .
Tomorrow i'll open one more time the wastegate and check everything ... I really don't understand ...
Re: Car gets 11 psi with 5 psi spring ! (blinx9900)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by blinx9900 »</TD></TR><TR><TD CLASS="quote">every time my boost creeps i smack it with a fly swatter and say BAD BOOST BAD!! </TD></TR></TABLE>
throw yourself down a long flight of stairs please
kthxbye
kthxbye
Re: Car gets 11 psi with 5 psi spring ! (LoseRPunKx182)
i'm using one behind the intake mani .
Prob Found !
It's a 35mm WG . I asked for a 38 Got to see with alex ...
Modified by panta83 at 5:58 PM 11/21/2006
Prob Found !
pavilionlivin
07-24-2010 04:25 PM
pushinlsteg
06-27-2005 06:54 PM
