oil sandwich adapter
Old Nov 18, 2006 | 08:31 PM
aryiman98civic's Avatar
Default oil sandwich adapter
i got an oil sandwich adapter and i put my stealthline 1/8th fitting in and it screwed in about two times, so it sticks out quite a bit. i was wondering if i need a non tapered fitting for this.....let me know, thanks
Old Nov 18, 2006 | 09:08 PM
boost4life's Avatar
hey wat brand is ur b/c i need to get one thanks
Old Nov 19, 2006 | 03:58 AM
Autoworks's Avatar
Default Re: oil sandwich adapter (aryiman98civic)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by aryiman98civic &raquo;</TD></TR><TR><TD CLASS="quote">i got an oil sandwich adapter and i put my stealthline 1/8th fitting in and it screwed in about two times, so it sticks out quite a bit. i was wondering if i need a non tapered fitting for this.....let me know, thanks</TD></TR></TABLE>
Usually the 1/8 NPT fitting that goes into the plate is non tapered/flared...just straight
Old Nov 19, 2006 | 09:24 AM
95dc2teg's Avatar
Default Re: oil sandwich adapter (Autoworks)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boost4life &raquo;</TD></TR><TR><TD CLASS="quote">hey wat brand is ur b/c i need to get one thanks</TD></TR></TABLE>
Funtion7 is a good brand
Old Nov 19, 2006 | 03:18 PM
HiProfile's Avatar
Maybe you should have checked what threads were on that sandwich before you screwed in a tapered pipe thread fitting. Pipe threads usually engage 3+ threads to seal, so maybe its not tight enough. As long as it doesn't leak a bit, then its fine.
Old Nov 19, 2006 | 06:24 PM
http://acautotechnic.bnetsoftw...TCode=
that is where i got mine from, ill tell ya in about a week and a half how easy it is to install
Old Nov 19, 2006 | 07:22 PM
riceball777's Avatar
Default Re: (aryiman98civic)
i have a brand new ac autotechnic oil sandwhich for sale $50 shipped pm me
i also use the ac autotechnic one
i prefure this one because it has 4 1/8 npt ports which is perfect. i use all for ports
1 for turbo oil feed
2 for lsvtec oil feel
3 oil pressor sender
4 oil temp sender
heres a pic
oil feeds on the left side and huge oil pressure sender on the bottom
you can see this but the oil temp sender in at the top
Modified by riceball777 at 4:36 AM 11/20/2006
Old Nov 19, 2006 | 07:34 PM
95jeremie's Avatar
Default Re: (riceball777)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by riceball777 &raquo;</TD></TR><TR><TD CLASS="quote">i have a brand new ac autotechnic oil sandwhich for sale $50 shipped pm me
4 oil temp sender
heres a pic
you can see this but the oil temp sender in at the top </TD></TR></TABLE>
PM"d ya
b00stedbyFastrax
Oct 9, 2007 07:51 PM
axionm1k
Sep 24, 2006 06:20 PM
Hwj_33
Sep 1, 2006 09:32 AM
Type-Rare#1248
Mar 15, 2005 12:29 PM
its WANG yoO
Jul 7, 2004 07:52 AM
