is it ok to drive with larger injectors and stock ecu for a little bit?
like the title says, is it ok to drive with larger injectors and a stock ecu if the rpm's are kept down? i have 450 cc injectors on my turbo gsr, and i need to get it to the tuner's shop to get the ecu socketed and tuned. will driving it there (30 minutes) do any damage to the engine?
Re: is it ok to drive with larger injectors and stock ecu for a little bit? (civicdxtyper)
Drive a spare car to your tuner with your ECU in hand.
Have him burn you a basemap.
Go home and install the newly chipped ecu and then drive back and get tuned.
If you dont have an extra car, your parents or friends do.
GL
GL
Re: is it ok to drive with larger injectors and stock ecu for a little bit? (jDMJeRk)
yeah i just decided to send in my ecu to phearable to have him socket it and burn a basemap. never mind about the original question.
Re: is it ok to drive with larger injectors and stock ecu for a little bit? (EK k kay)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EK k kay »</TD></TR><TR><TD CLASS="quote">It wouldn't even idle with the larger injectors.</TD></TR></TABLE> YEA RIGHT, MINE IDLED LIKE STOCK WITH 450s.
Re: is it ok to drive with larger injectors and stock ecu for a little bit? (UNKNOWN_MEMBER)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by UNKNOWN_MEMBER »</TD></TR><TR><TD CLASS="quote"> YEA RIGHT, MINE IDLED LIKE STOCK WITH 450s.</TD></TR></TABLE>
what were your AFR's? prolly washing out your cylinder walls
Re: is it ok to drive with larger injectors and stock ecu for a little bit? (dunkd)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by dunkd »</TD></TR><TR><TD CLASS="quote">
what were your AFR's? prolly washing out your cylinder walls </TD></TR></TABLE>
i think he means with his tuned or basemap 450cc idles like stock. he probably didnt even read the whole question.
Mr. Badwrench
Re: is it ok to drive with larger injectors and stock ecu for a little bit? (komat)
it may have idled with 450's on a stock map, but it wont be well. my car wouldnt even start with 550's.
Re: is it ok to drive with larger injectors and stock ecu for a little bit? (boostedcivicsir)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by boostedcivicsir »</TD></TR><TR><TD CLASS="quote">it may have idled with 450's on a stock map, but it wont be well. my car wouldnt even start with 550's.</TD></TR></TABLE>
try starting my car with 1600cc and aem haha takes days to start haha
em1_sir
12
10-18-2007 08:01 PM
