Need some wide band help
Old Nov 14, 2006 | 04:18 PM
MJobe's Avatar
Default Need some wide band help
https://honda-tech.com/zerothread?id=1810155 i fugured i would post in hee there is just a little more action in here..
thanks for the help
Old Nov 14, 2006 | 04:29 PM
coneheadsracing's Avatar
Default Re: Need some wide band help (JOBEYYYYY)
https://honda-tech.com/zerothread?id=491428
https://honda-tech.com/zerothread?id=1653446
Old Nov 14, 2006 | 05:36 PM
MJobe's Avatar
Default Re: Need some wide band help (coneheadsracing)
thanks for the link but do i need my stock narrowband sensor in? or should i tap wires into the wide band from the narrow band wiring to make the computer think it is still reading the stock o2 so it doesnt throw a CEL? im kind of stumped
Old Nov 14, 2006 | 05:42 PM
BoostedB16EJ's Avatar
i tried wiring my aem in to replace the oem... even called aem tech support on it. it never did work out for me. i finally just welded a bung into the downpipe for the wideband
Old Nov 15, 2006 | 03:56 PM
Default Re: Need some wide band help (BoostedB16EJ)
I'm unsure about AEM, but with uberdata and crome i believe you can select what o2 sensor you are running. You have to disable the o2 heater, and then wire in the narrowband signal. D14 i believe for the d-series. Not sure though. I've done it before, but i just use a second bung and that way i can pull it out and tune my friends cars for them.
Old Nov 15, 2006 | 08:35 PM
MJobe's Avatar
Im just getting another bung welded in for the wideband , thanks for the help guys!
Old Nov 15, 2006 | 08:56 PM
drtysohc's Avatar
lots of wideband controllers have a narrowband output.
MJobe
Nov 22, 2006 05:50 PM
lsvtecracer
Sep 18, 2006 10:22 PM
WildPig
Jun 4, 2005 11:30 AM
BoostedJeff
Oct 18, 2004 05:46 PM
BoostedSi
Mar 23, 2003 09:13 AM
