suggestions on my engine build ?
Old Nov 21, 2006 | 08:37 PM
rsdriver17's Avatar
Default suggestions on my engine build ?
i not sure what i want to do here. i have a b18a1 never touched. i was thinking of doing an OEM build with arp rod studs and some head work pushing 10lbs, tuned of course. but im not sure if thats the way to go or not. im sorta on a buget and im trying to avoid burning 400 - 500$ on pistons if i dont have to but... any build ideas please let me know
Old Nov 21, 2006 | 10:47 PM
Schister66's Avatar
Man U FTW
do a compression and leakdown test before you turn a single wrench on that engine....there is no reason to tear it apart before you know what condition its in
ARP's are a good idea
Old Nov 21, 2006 | 10:52 PM
SiKid86's Avatar
Default Re: (Der Schistinator666)
I agree. If you rebuild you might as well spend the ~800 for the forged rods and pistons. I had Wiseco pistons and eagle rods in my ls/vtec and I had no issues at all.
Old Nov 21, 2006 | 11:34 PM
Schister66's Avatar
Man U FTW
on a completely unrelated note....i can't wait to do my build
Old Nov 22, 2006 | 04:18 AM
rsdriver17's Avatar
well i believe at one time i did do a comp test and they werent all the same but not to far apart. it does smoke slighty so...
Old Nov 22, 2006 | 04:24 AM
Swipe'd's Avatar
just 2 add, thou it might hurt the pockets now, its better to do your bottom end in the startin stages, so later it doesnt rise as a problem when desire'n more power
Old Nov 22, 2006 | 07:22 AM
rsdriver17's Avatar
Default Re: (Swipe'd)
true,, my friend was pushing 300 on a b16 stock bottom end at 10 lbs are they any stronger ??
Old Nov 22, 2006 | 07:25 AM
Schister66's Avatar
Man U FTW
i'm making about the same on a GSR stock bottom end....personally if you're going to tear it apart, build it correctly while its apart
Old Nov 22, 2006 | 09:19 AM
rsdriver17's Avatar
what would be a good estimate price for a rebuild, to do it up right
Old Nov 22, 2006 | 04:41 PM
rsdriver17's Avatar
Default Re: (rsdriver17)
bump $$
Old Nov 22, 2006 | 05:02 PM
doood's Avatar
been there done that
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by rsdriver17 &raquo;</TD></TR><TR><TD CLASS="quote">what would be a good estimate price for a rebuild, to do it up right </TD></TR></TABLE>
with new forged internals, $2500-$3500 for a fully assembled shortblock from some reputable shops here on h-t. cheaper if you provide some of the parts or just stick with oem internals.
Old Nov 22, 2006 | 05:28 PM
Topdawgg's Avatar
it depends on how strong you want it....
stock bore stock internals is good for 300whp easy on that block...
if you want some piece of mind, throw some forged internals and head studs in it... with a fresh bore if needed... make 400+
if you want REAL satisfaction, get the block sleeved..
Old Nov 22, 2006 | 09:21 PM
mrrogers1's Avatar
Default Re: (that one doood)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by that one doood &raquo;</TD></TR><TR><TD CLASS="quote">
with new forged internals, $2500-$3500 for a fully assembled shortblock from some reputable shops here on h-t. cheaper if you provide some of the parts or just stick with oem internals.</TD></TR></TABLE>
Earl does a complete shortblock (pistons, rods, sleeves, bearings) for $3100 plus shipping. http://www.laskeyracing.com/shop/bseries.htm
Old Nov 23, 2006 | 09:38 PM
SiKid86's Avatar
Default Re: (mrrogers1)
~500 pistons
~350-400 rods
~150 bearings
~50 to hone the block
~35 to press rods on pistons if you need that
~50 misc stuff
~100 arp/aebs head studs
~40 to get the crank polished and what not.
Thats about it if you can put it together your self.
Old Nov 23, 2006 | 09:39 PM
rsdriver17's Avatar
Default Re: (Topdawgg)
really all i was looking for is something around 300, for now that is
Old Nov 23, 2006 | 09:42 PM
rsdriver17's Avatar
also i am short of the cash and i want it to be done for spring, for import carlisel!!
ElswickB22
Aug 6, 2013 08:44 PM
allmotor99lude
Jan 4, 2006 11:37 AM
DarkTeg94
Dec 26, 2005 10:30 PM
PnkRokCountryboy
17
Nov 20, 2005 04:08 PM
erebunicrx
12
Nov 5, 2004 07:32 PM
