Injector Resistor Box?
Old Nov 14, 2006 | 03:50 PM
EX-T's Avatar
Default Injector Resistor Box?
I've searched and only found threads about buying and selling these boxes.
Will any '88-'91 Civic injector resistor box work for DSM 450s or any high impedance, Peak and Hold injector?
Old Nov 14, 2006 | 03:56 PM
boostedcivicsir's Avatar
Mr. Badwrench
Default Re: Injector Resistor Box? (EX-T)
ohm the injectors, if they are 2-3 ohms you need an 88-91 civic resistor box. if they ohm 12-12 ohms you dont.
but if they are dsm's, you will need a resistor box. and yes a 88-91 si box will work. ps, i am running RC 1200's p&h with an ef resistor box.
Old Nov 14, 2006 | 04:04 PM
EX-T's Avatar
Default Re: Injector Resistor Box? (boostedcivicsir)
So only the '88-'91 Si box will work?
Old Nov 14, 2006 | 04:08 PM
coneheadsracing's Avatar
try searching again, and this time pick the turbo forum, that should get rid of all the classifieds for ya. I don't know the answer, i feel like there are others that work though.
Old Nov 14, 2006 | 04:21 PM
Mr. Badwrench
any 10watt 10ohm resistor will work. so if you have a resistor box that is 10 ohm, as long as it can disspiate the heat you are fine.
Old Nov 14, 2006 | 08:12 PM
EX-T's Avatar
so the resistor box is just for neatness? I've got 100+ 10ohm resistors....it's OV!
Old Nov 15, 2006 | 01:34 AM
Mr. Badwrench
the 10w 10ohm resistors i was gonna use were lke 1/4" square and like 1 1/4 long and i dont think they would look right soldered in liine to my injectors. and i have my resistorbox hidden, so for clenliness,i think they are better.
Old Nov 15, 2006 | 12:25 PM
EX-T's Avatar
The ones I have are cylindrical and pretty small. Nothin' a little shrink wrap can't fix!
Old Nov 15, 2006 | 04:34 PM
NJIN BUILDR's Avatar
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by EX-T &raquo;</TD></TR><TR><TD CLASS="quote">The ones I have are cylindrical and pretty small. Nothin' a little shrink wrap can't fix!</TD></TR></TABLE>
The resistor boxes have a heat sink.Small resistors with shrink wrap sounds like the wrong direction.
Old Nov 16, 2006 | 08:29 AM
EX-T's Avatar
Default Re: Injector Resistor Box? (NJIN BUILDR)
<TABLE WIDTH="90%" CELLSPACING=0 CELLPADDING=0 ALIGN=CENTER><TR><TD>Quote, originally posted by NJIN BUILDR &raquo;</TD></TR><TR><TD CLASS="quote">
The resistor boxes have a heat sink.Small resistors with shrink wrap sounds like the wrong direction.</TD></TR></TABLE>
Why is that the wrong direction? 10ohm resistors aren't going to dissipate that much heat. The reason the resistor boxes have a heat sink is probably b/c the resistors are in close proximity, meaning more heat.
avotegra
Apr 6, 2007 11:57 PM
birz
Jun 21, 2006 05:02 PM
redboost10
Oct 23, 2003 03:35 PM
